Question about Dishwashers
Miele G638 CS Plus - Salt PC light flashes and will not run
Our Miele G638 Dishwasher is 4 years old and never had any problems until today.
Switch On the Power and the Salt PC LED flashes non-stop at about 2-3 times per second regardless of the Settings.
Pressing the Start button has no affect.
Powering Off for 30+ minutes makes no difference.
Can I somehow 'reboot' the processor?
  • Anonymous Mar 13, 2014
    The dishwasher goes through it's start up process and then when it starts to wash it trips the power in the kitchen immediately.
  • 83 Answers
Have you added salt to unit?If so then you have a water intake problem or unit is oversudsing.
Posted on Dec 08, 2007
  • Glen shaw
    Glen shaw Dec 08, 2007
    turn off breaker and that should reset unit Also call miele and ask them they have a great customer support.
  • Glen shaw
    miele phone # 1-800-999-1360
Are you using the correct salt? it can be bought from www.easicook.co.uk
Posted on Sep 10, 2008
Miele dishwaher G638 Sc,,,,Salt PC light is on?
Hi - if its flashing rapidly then there a unrecognized hardware issue -if on permanently - it could be the float switch inside the salt container is not working/jammed - of course theres no salt in the dishwasher container..
Cheers
Jul 20, 2011 | Miele 24 in. G638 Plus Free-standing...
On my Dishwasher Miele G638 Plus, a red light shows up and it says PC salt, I dont know how to solve this, please help me.
Hi - its possiblily the following issues if its flashing rapidly then the electronic module maybe faulty. The other possibilties are the float switch inside the salt conatner is jammed or the reed switch for the float switch in the salt container does work.
May 30, 2011 | Miele 24 in. G638 Plus Free-standing...
Inlet/drain light flashes on miele dishwasher and water will not completely drain away. Model G638l plus help please
the pump is blocked, need to remove the trays, drain plg, the gauze, scoop the water out as much as possible, thge thers a plastic hosing with a spring clip on top, remove this to unblock the pump. assemble & should be good to go.
May 23, 2011 | Miele 24 in. G638 Plus Free-standing...
The G638 finished its cycle but didn't completely
pump maybe on it's way out, though i doubt it, is the washing machine on the same drain out? if so you may have back wash, another could be lengh of drain hose, i had the same problem with my miele dishwasher because of the position in the kitchen i doubled up the drain hose and though it pumped out fine, with the volume of water left in the hose it came back in untill i repositioned the drain hose so it could't run back, hope this helps.
Aug 03, 2009 | Miele 24 in. G638 Plus Free-standing...
Water leaking from under the machine (Miele G638 Plus) dishwasher
The salt tank is a pathetic piece of ****. The plastic cracks and leaks into the bottom tray, which in turn sets off the safety switch.
Follow the attaching hoses and bypass the salt tank unless you really need it. This will save you around $250 for a salt tank and $300 labour for callout and repair.
Mar 23, 2009 | Miele 24 in. G638 Plus Free-standing...
Salt PC indicator light
I downloaded the manual off line and it gave me the facts I needed.
Thank you,
Markus
Sep 08, 2008 | Miele 24 in. G638 Plus Free-standing...
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Dishwasher will not start
Check the drain pan area under the dishwasher, if it full of water it will trip a float switch and run the drain pump until the water evaporates or is removed by a shop vac.
Oct 03, 2006 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
2,091 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
