Question about Samsung (SH-S162L/BEBN) DVD RW Burner
TSSTcorp CD/DVDW SH-S162L errror code 0x80020043
Mac G3 500 Mhz with the above drive reports an error code of 0x80020043 while attempting to burn from DVD Studio Pro to an 8 cm DVD media.
Odd thing is this same machine burned to this same media just a week ago.
What has changed?
  • Anonymous Aug 09, 2008
    Hello, I have the same problem. Have you a solution?
    Thank you very much.
                                             patrick
  • Anonymous Sep 26, 2008
    le mas não grava dvds
I have a single ide bus MB so the HD and the DVD player are on the one cable. I can not get the computer to boot after successfully installing the DVD and Firmware upgrade. If I change settings the (Master/Slave/Cable Select) then the drive shows up in BIOS and the PC boots. I search for new hardware, the drive is found, installed and will work until the PC is rebooted. Then though the bios show tboth devices it will not boot. If I unplug the DVD all is fine. The drive does not reappear unless I change some setting,but it does the same. I have tried new IDE cable. Drive does not show up on a USB IDE/SATA connector..
MB is and INTEL with 3 gig Pentium less than 6 month old. 512 Ram
Posted on Mar 09, 2008
  • vikingeric Mar 09, 2008
    PC does not boot period and unfortunately there is only one ide connector though there are four SATAconnector and a floppy connector. I don't know what Intel was thinking
  • 38 Answers
The problem might be with you cable remove the cable of your writer and plug it to another id port after pluging in install the drivers of the writer, this should solve your problem, if not then go to computer manager in that disk drives in that find the name of your writer. first disable it for a second then enable it now go to its properties and in that just press the button of check for updates, your screen will blink once and your drive will be installed properly.
Please vote me if you like the solution >Karatela
Posted on Dec 07, 2007
My TSSTcorp CD/DVDW SH-S162L SAMSUNG won't read or write to any disk I insert,when I perform windows troubleshoot it indicates that my device is working properly.I am using windows xp service pack 3.
Hi There and Welcome to FixYa!
It's a good thing that you have a Windows operating system because these issues can be easily fixed. You can visit the site I provided through the link below (from Microsoft) :
Microsoft Drive Repair
Download the repair application by clicking "Run Now". Before initializing the repair after completing the download, make sure that there are no other running applications as it will prompt you to restart the computer for the fix to take effect.
I hope this one helps, Thank you for using Fixya.
Mar 09, 2011 | Samsung SH-S162L (SHS162LBEWN) Burner
The TSSTCorp CD/DVDW SH-S162L can't read or write on DVD-RW ?
As you say your DVD-RW is not read or write disk it is simple that your device lens became weak. But before replacing it with new one use lens cleaner cd to clean your device lens.Maybe it works and save your money.
Aug 23, 2010 | Samsung (SH-S162L/BEBN) DVD RW Burner
TSSTcorp CD/DVDW TS-L632D ata dvd drive doesn't burn!!! Vista HP
Most of the time MEMOREX brand is not compatible with HP.
Try a diffrent brand and check if it works.
Jun 05, 2010 | HP Computers & Internet
My tsstcorp cd/dvdw sh-w162z wont play wont rip and burn.
your DVD ROM lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working again but be careful remember that no power should be attached to ROM.
or you can buy a lens cleaner from market and try that.
pls rate my solution
thankyou
Feb 16, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
DVD drive dont work
If you have Two cd/dvd drives make sure one is set to master and one to slave to do this on the back of the dvd drives is what looks like a piece of plastic there will be two rows of 4 pins for master the plastic piece should on the right hand side next to the long slot for slave move it one pin away from the long slot keep me posted please
Jan 13, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
How do I use this DVD writer?
Deep Burner is an option, you can copy the files off the old dvd, and burn them to your new dvd. This software is very easy to use!
www.deepburner.com
Aug 07, 2008 | Samsung (SH-S162L/BEBN) DVD RW Burner
Low speed burning problem on SH-S162L TS08
http://www.winhlp.com/tools/resetdma.vbs
save and run this script on your computer!
Oct 14, 2007 | Samsung (SH-S162L/BEBN) DVD RW Burner
TSSTcorp CD/DVDW SH-S182M
We have the same problem here with this Samsung DVD burner & want to know if you have found a fix for it.
mail@atticusarch.com
Oct 08, 2007 | Samsung (SH-S162L/BEBN) DVD RW Burner
Samsung (SH-S162L/BEBN) DVD RW Burner Logo
1,087 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
