Question about Tefal AquaSpeed FV5155003 Iron
Question on iron manual
Like my new iron but it's 'fancy' and I live in Japan and it came only with a Japanese language you know where I can find an online English manual for this iron? Thank you.
0 characters
1 Points
How do I get rid of of black dirt that is coming out of steam holes?
it is corrosion build up in the iron
you can try a quality steam iron cleaner but that process is generally short lived and the problem will return
The normal fix is a new iron and using only demineralized water-- not tap water
Jan 18, 2016 | Irons
Why does water leak out of bottom of iron base unit when ironing .could it be the filter unit ?
Probably not the filter.
If it is a new iron and the drops of water are excessive I would suspect it is faulty.
If the iron is well-used I would suspect it has a scale problem where localised scale build up is preventing some of the water from closely contacting the heated metal and turning to steam. This could be particularly true if you live in a hard water area.
Steam irons originally soon caused problems unless distilled or de-ionised water was used. It is reckoned modern irons can use tap water but hard water can still cause trouble.
A descaler additive might help but I haven't had good results in the past...
Oct 19, 2015 | Irons
My Siemens TX20 Extreme Power iron says that it has no water when it is full. is there a reset button or something that I should know about?
Sounds like faulty Sensor, to expensive to repair , If you are happy that you can see water level and can live with it OK. Otherwise it's a NEW IRON
Mar 14, 2015 | Irons
I have had a laurastar iron bought from John Lewis on the. 16/01/10, it has just exploded on me, please let me know if I Can get in touch with someone to repair it ? I live in glasgow, thank you look
cannot look into your wallet ...but i would just get a new one or secondhand these things are so sensitive with their water connections once you take it apart you cannot get it together again without leaking...
Nov 11, 2014 | Irons
Euro steam evolution iron model 6399
I just got my iron and got into an immediate argument with my husband when I read the manuel, which said "made to use tap water"....."NEVER USE 100% DISTILLED WATER". I was about to return it when I decided to call the customer service number and lo and behold, my husband is right! I\'ll never live that one down. The person on the phone said they\'d been trying to get the manufacturer to change that in the manuals for a long time. I\'m really annoyed - but you do need to use distilled water in this iron. I\'m still thinking about returning it just because of the argument.
Jul 16, 2012 | Irons
My rowenta iron is not steaming as it should
If you live in a hard water area it may be lime scale, only use cheap bottled water to fill this machine Dont know where you live but in England 2lts(4 pints) of still water is £0.12 from Asda and Tesco
Nov 07, 2009 | Rowenta Irons
Iron just stopped working, no lights, no heat no iron Opened back panel to make sure no loose wires or damage inside. The inside still looks bran new and the wire cap connectors are intact. Iron may be 2-3...
check plug fuse, if ok, check continuity of the live, neutral and earth conductors for a break. if ok, element may be faulty. Any smell of carbon burning?
Oct 26, 2009 | Irons
Tefal AquaSpeed FV5155003 Iron Logo
Top Tefal Irons Experts
Ryan S
Ryan S
Are you a Tefal Iron Expert? Answer questions, earn points and help others
