Random ARC Picture Size Change
While watching the tv, the size of the picture changes as if the ARC button is being selected. We have had the tv for a month and the problem occurred a week ago after my daughter had 'played' with the remote control - I think she held down the ARC button! I have tried the usual things ... turning off the power to the tv, selecting another tv size through the ARC button, and resetting the factory settings through the Menu options, but this only works while watching at that time. If I then watch something on Sky that has been pre-recorded the problem comes back. Any suggestions? Thanks. the picture of the becomes smaller than that of its original size
  • delashark Dec 29, 2008
    Same deal. It started after the kids messed with the remote. It does not happen on HD channels though.
    Scholar:
  • 137 Answers
What Brand TV do you have? What cable box are you using?
Posted on Dec 08, 2007
Need to change the size of the TV picture
Hi David,
There is key P Size on the remote control. Please use it and select the size of picture you need.
Jul 01, 2015 | Televison & Video
The picture exceeds the size of the screen and the outside of the picture is missing
Change the image size with the 'picture size' or 'format' button on the remote. On some tv's you have to go into the menus to change the size if there's no button on the remote control.
Mar 17, 2015 | Televison & Video
Remove wide screen
In order to change the picture settings that affect picture size use the button on your remote marked aspect. If you want to change picture settings such as color, brightness, etc., use the menu button and select Picture, then hit Ok to enter that menu.
Feb 08, 2015 | Panasonic Viera TX-32LX70 32 in. LCD TV
43 inch plasma samsung tv with abnormal picture size .i want to adjust but i dont have serivce menu codes please help.
Using The Remote Control Your remote control will have a button on it to quickly adjust the picture size.
  1. Press the P.SIZE button.
  1. The current picture size will be displayed on the screen.
  1. Press the P.SIZE button repeatedly until the desired picture size is selected.
  2. Important: Some picture sizes are only available with certain resolutions or certain inputs.
Using The On-Screen Menu
  1. Press the MENU button. [The Main Menu appears]
  1. The Picture portion of the Main Menu will be selected by default, if it is not selected use the directional arrows to select the Picture portion.
  1. Use the directional arrows to select Screen Adjustments, and then press ENTER.
  1. Picture Size will be selected by default if not use the directional arrows to select Picture Size, and then press ENTER.
  2. Note: The current picture size selection will be displayed to the right.
  1. Use the directional arrows to select the desired picture size, and then press ENTER.
Nov 12, 2013 | Cell Phones
A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
Jun 07, 2011 | LG 32LG30 32 in. LCD HDTV
How do i change my pictue size using remote control
Hello
To select the picture size using the remote control
Press "Picture Size Button" on the remote control
While the Picture Size screen is open, you can do one of
the following to select the desired picture size
Repeatedly press "Picture Size Button"
Press the corresponding Number button (0-6) while the
Press UPor DOWN button, while the Picture Size screen is open
Using these functions to change the picture size (i.e.,
changing the height/ width ratio) for any purpose other than
your private viewing may be prohibited under the Copyright
Laws of the United States and other countries, and may
subject you to civil and criminal liability
OK
May 11, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
Full tv screen is not being diplayed horzontally.
First thing to check is the picture size. You can view many program formats in a variety of picture sizes
  1. Natural
  2. TheaterWide 1
  3. TheaterWide 2
  4. TheaterWide 3
  5. Full
  6. 4:3 HD
  7. Native
  8. Dot by Dot.
The format of the image will vary depending on the format of the signal you are currently watching from you cable or satellite provider. Select the picture size that displays the current program the way that looks best to you.
To select the picture size using the remote control:
  1. Press I on the remote control.
  2. While the Picture Size screen is open, you can do one of the following to select your desired picture size:
• Repeatedly press I.
• Press the corresponding Number button (0–6) while the Picture Size screen is open.
• Press B or b while the Picture Size screen is open.
To select the picture size using the menus:
  1. Select Picture Size in the Theater Settings menu.
  2. Press C or c to select the desired picture size setting.
  3. Highlight Done and press T.
Some of the picture sizes may not be available depending on the receiving signal format from your cable or satellite provider (those will be “grayed out” in the Picture Size screen).
Second thing to check is the Native Mode which restores the size of the picture by the 3-5% that is generally lost during the normal over scanning that occurs on traditional sets. It also avoids unnecessary scaling of 1920 x 1080 HD signals. I hope this helps and good luck!
Feb 24, 2010 | Toshiba REGZA 52RV530U LCD TV
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
