You don't. At least you don't normally need to. There are two spring clips that hold the top on and you have to release these to raise it up. They are located about three inches from each corner in the front. UNPLUG WASHER FIRST!!!!! Take a flat screw driver and GENTLY ease it between the top and front panel and look in the crack. You should see a flat piece of metal sticking up into the top. Use your screwdriver to push this back until it releases the top. Do the same thing on the other side and the top should lift up and back.
Now, why do you want to get inside it?
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE WVSR1060A Top Load Washer
My washer makes an awful grinding noise when it is spinning, at first I thought it was the tub being...
(More)
My washer makes an awful grinding noise when it is spinning, at first I thought it was the tub being to loose, but checked for the bungee cords that attach to the tub and they are there and perfectly fine. It has something to do with the spinner, I believe.
My washer makes funny noises when agitating and spinning, also is leaking water from the bottom. can...
(More)
My washer makes funny noises when agitating and spinning, also is leaking water from the bottom. can this be fixed at home or does it need a repairman
I have a Kenmore washing maching 90 Series 26902690 that when I start it the water fills very slow....
(More)
I have a Kenmore washing maching 90 Series 26902690 that when I start it the water fills very slow. Two days ago it was fine, then it got off balance and is now doing this. What should I do?
kenmore 90 series washer does not fill, does not agitate, will spin to remove water if in tub. Timer...
(More)
kenmore 90 series washer does not fill, does not agitate, will spin to remove water if in tub. Timer does not appear to run as dial does not advance.
