DISH Network DVR 510 DTV Receiver / 100-Hours Video Recorder
Problem for DISH Network DVR 510 DTV Receiver / 100-Hours Video...
Does not receive 110 side
By a_mizrahi on Sep 02, 2009
does not receive 110 side
Solution #1
posted on Sep 02, 2009
Not Rated)
denz_maveric
Rank: Wiz
Rating: 84%, 117 votes
Hi a_mizrahi! I will be more than glad to assist you in thhis concern. If your model 510 dvr receiver dont get the sat 110. Lets check 1st the cable connection on the back of the receiver, make sure that the cable connected on sat in is connected hand tight and check as well if the cable is going to the wall with a connector as well. Then press the menu button on the upper left of the remote, it will pop up the main menu, once you got it, press number 6-system setup, 1 installation, 3 system info, It will show the system info one. check on the field letter g, you will see sat number, ex only 119, bcoz you cant get 110, check if sat 119 is green on the buttom box, if its green then select cancel on the screen, then select 1 pointdish, select on check switch then once you are on the install summary, select test on the buttom portionof the screen. It will run a test it could be 1 of 2 or depends on the situation of your sat dish.. wait till it finish. once its finish, it will show the install summary, check if you have, input1-119-all- device name, input2-110-all-device name, or it could show this way, input1-119-odd-even, input2-110-odd-even, if you got 110 on the input after the test it means that we are almost there to fix the problem.. select cancel on the screen, cancel all the way out of the menu until it will pop up attention 015, it should show a progress up to 5 of 5 then it will download the programming guide, wait until it finish the download and it will pop up a picture right away on the tv. let check if the 110 is ok, most of the channels broadcast under 110 is your local channels and some upper channels from the sat.. press menu and then main menu willshow, press 6, 1, 3, back to system info one, check on the field g if sat 119-green, 110-green, if there is no 110 showed on the field g, cancel alll the way out of the menu, then press the power button on the front panel of the receiver for 10secs to reset the system, it should show on the front panel of the box that the power light will turn off and turn back on by itself, then it will acquire the sat signal again, it will go to the process of finishing the progress and download the program guide again, just incase the front panel reset didnt work, do the hard reset by unplugging the power of the receiver to the wall outlet for 1minute. then plug it back in, it will go to the progress again and download the programming guide.. check again the sat on the system info one, by pressing the menu button on the remote, press 6,1,3, check sat 110 is there and 119, it should be green on the button. granting still no 110 sat, select cancel, then select on the screen updates - option 4 I think, once your there, check if without my permission is selected or check, then save , cancel all the way out of the menu, once you got a picture, press the power button on the remote to turn off the receiver, leave the tv on, wait for a few secs and it will pop up attention 061, downloading vital program information, this msg will appear if your software version is outdated.. wait until it finish and once its finish the tv screen will turn black or snowy screen and no lights on the front panel of the box. push the power button on the front panel of the receiver for 10secs to reset the box and wait till it acquire the sat signal and download the programming guide, this should fix the problem, if there is no changes, please call dish network tech support @ 1-800-333-DISH, to check your sat system, there is a possibility that there is a problem on the alignment of the dish, switch or lnbf..
Was this helpful?
Yes
No
Popular Solutions for DISH Network DVR 510 DTV
Questions and Unsolved Problems for DISH Network DVR 510 DTV
Do you recommend DISH Network DVR 510 DTV Receiver / 100-Hours Video Recorder?
Answer
Answer
My recorder will not link up to my tv any more. When switched on the power is there and lights flash... (More)
Answer
''how to remove parental controls from k1 heroplus'' Problem Now!
Answer
My Grundig GUSTB801V digital TV recorder was in record mode and I noticed the disply had changed to... (More)
Answer
master tv makes a horrible noise for 2-3 mins and when going to and from commercials. 36" tube... (More)
Answer
TV showed "Problem Detected" with a possible solution of unplugging my unit for 60 secs.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For DISH Network DVR 510 DTV...:
Top TV Receiver and DVR Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more TV Receiver and DVR Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
