Question about Car Audio & Video
Wiring-audio system-1989 ford crown victoria
Trying to install new kenwood receiver- 2 eight wire plugs on factory harness don't match colors on new radio harness
  • 2 more comments
  • cat1978 Dec 07, 2007
    need to know the function of each of the 16 wires on the factory audio harness- 1989 ford crown victoria
    haynes manual had all electrical schematics except the audio system-only
    haynes manual didn"t show radio wiring-only showed how to remove and install receiver
  • Jay12345 Feb 13, 2008
    I need to hook up my stereo harness to the crown Victoria's existing harness but i cant find the color codes any ware
    I have looked everywhere on the internet and cant find it any ware
    i just need the color codes/wiring diagram
Tell Haynes not to cheap out and try to fit a decade of cars inton one book...I cant find the fuse block legend anywhere...what a rip
Posted on Oct 11, 2008
  • 625 Answers
Go to an autozone or advance auto parts store and find a haynes auto manual for your car. electrical diagrams are in back of the manual.
Posted on Dec 07, 2007
How to install a Kenwood kdc 138 in a 1992 Ford Escort LX?
if its anything like my 92 ranger you take the dash apart around the radio and the stereo should unscrew, in my ranger the new cd player went in without any extra harness as it was the same size as the stock, if not you can but harnesses to go where your old stereo did, to connect the speakers you can buy a ford wiring harness from walmart or any store with an audio department. these plug in to your vehicles wiring harness so you don't have to cut it out, after that you simply match colours from the wires of the new cd player to the wiring harness
Dec 25, 2013 | Kenwood DISCONTINUED - KDC-138 In-Dash CD...
No sound.
The first thing you need to do is doublechecking all the new wirings, it sounds like a contact.
Oct 24, 2008 | Kenwood KDC-MP338 Car CD Player
I can't installer this radio it a ford crown victoria 2007 .. I remove the radio than I put a new one it doesn't works
you need to connect the yellow wire coming from your new radio harness to a wire with a constant 12volts even when your car ignition is off.
Feb 04, 2013 | Car Audio & Video
Installing a jvc cd player into a 99 crown vic
the best thing to do is not to cut factory wires and buy a wire harness from walmart or miejer and the wires will be color coted match up and tape them up them plug the two harness's together that is the best way to wire up a aftermarket radio
Sep 24, 2012 | JVC USB/CD Receiver with Dual AUX Input...
What's your problem?I drive a 1999 ford crown victoria. This unit did not come with a a wire harness.. so how do i install my Kenwood KDC-138 FM / AM Receiver correctly
you need to go to any appliance store that cells cd players and buy a wire harness that connects to the cd players wires its called a ford wire harness, the people at the store should know where and what it is.
Oct 17, 2011 | Kenwood KDC-138 FM / AM Receiver
I am trying to connect a kenwood KDC-MP3035 to a 1997 Honda Passport but none of the wires match up, what do i do to make it work?
Hello oz101ez,
The wires have to be matched by function, not by color. Here is a link to the color code for the stock radio harness in your Passport. Connect whatever color wire your Kenwood manual says is for 12V + (usually yellow for most aftermarket receivers) to the "red/white" in your Passport. Connect the Kenwood accessory wire (usually red) to the brown/white wire in your passport. Just continue matching up each wire function and colors on both ends.
Best would be an aftermarket wiring harness vehicle specific for the Honda Passport/Isuzu Rodeo. The Metra 70-7712 seems to be the correct one for your vehicle. probably has the largest selection of wiring harnesses available anywhere. They'll even match the vehicle harness to an aftermarket receiver harness and connect them using solder and heat-shrink insulation if you desire.
Most local car audio shops will carry some wiring harnesses. Also retailers like Best Buy may have them, albeit at much inflated prices. Online car audio retailers like and have a good selection and their prices will probably be somewhere in between, lower than local but higher than
Hope this helps.
Aug 05, 2009 | Kenwood Car Audio & Video
Installing newer radio in older truck
Hello zachary_reed,
What you need is an aftermarket wiring harness. These are made by Metra, Scosche, and others and are made to plug directly into the OEM radio harness. It appears that the one you want is the Scosche FB02B available from SonicElectronix. You simply connect the wires from your new receiver to the harness wires and then plug it into the factory radio plug. Another online retailer that sells aftermarket harnesses is Your local car audio shop or perhaps Best Buy may also have the wiring harness.
Be sure to match up the wires from your new radio harness to the aftermarket harness by FUNCTION, not by color. For example, most newer receivers will use Yellow as the 12V constant (hot) wire. The wiring color code for your F150 is shown here. Make sure that the pin on the aftermarket harness is connecting the yellow from your new receiver to the green/yellow of the OEM plug and so on.
Hope this helps.
Jun 09, 2009 | Pioneer DEH-1100 CD Player
Kenwood cd player to an 05 jeep - no sound
Hook the Blue/white striped wire to the power antena lead of the jeep (blue) to turn on the factory amp
Apr 17, 2008 | Kenwood KDC-135 CD Player
Car Audio & Video Logo
768 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
