Question about Compaq Presario R3000 Notebook
Compaq presario r3000
What it does is, boots up okay, but then at slightly varying lengths of time, between 2 and 10 minutes, it just shuts down abruptly, like it had no battery and I simply pulled the adapter plug out. shuts down cold without warning.
I though maybe the anti-virus program (norton) had gone awry, maybe shutting it down because of some virus, but there would be a warning of some kind.
Power source is working, checked the output with a voltage meter and it was producing just a bit over 18 v.
I knew of a sony vaio that had the same type of issue, so I was wondering if this may be a proprietary problem, or could it be a proprietary owner mistake that causes it?
I need suggestions as to what to look for, I really like this laptop and don't want to get another brand.
  • trid2bnrml Dec 12, 2007
    Okay, that makes sense...I never really paid attention to whether the clock was set at the right time or not--I was too busy trying to find the problem with the external power source.
    I'll get back to ya on this---
  • 625 Answers
Check the battery that powers your cmos. if your laptop is like my compaq armada, there's three screws at the top which free up the keyboard cover. there are three latches near the bottom of the keyboard. the keyboard swings up towards the top. there's two film type connectors in the middle of the motherboard. pull these out and the keyboard comes free. look in the upper left part of the laptop for a small disk type battery with a red and black on white nylon connector. replace this battery. it is a lithium-ion battery.
Posted on Dec 07, 2007
Compaq Presario R3000. Push power button and lights come on then goes dead before booting. Occassionally Windows will start booting the it goes dead. Any suggestions?
Either the power supply is putting out too low voltage or the power jack is bad.Try moving the ac adapter tip around while its starting up to see if it keeps it running or shuts it off.If it makes no difference try another ac adapter that does work for sure and see if thats the problem.If neither approach works,then the HDD may be seizing or one of the ram sticks may be bad.Some sort of hardware conflict can cause shut downs.You would have to take the bootstrap approach to narrow it down to one pacific component.
Aug 02, 2009 | Compaq Presario R3000 Notebook
Compaq presario r3000 amd athlon laptop cuts off after 10 minutes
from my experience this might be one of two things...
if it's shutting down while you're installing windows, i'm thinking you might have a problem with the motherboard channel for your CD drive. i saw this happen to a computer at work - we couldn't install windows because it cut off halfway through and blue screened on us.
it might also be a case of a bad hard drive, if you have any testing utility like drive fitness test i'd give that a shot. it sounds like a new one, but they're bad out of the box sometimes.
hope this helps
Jan 15, 2009 | Compaq Presario R3000 Notebook
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Compaq presario R3000 Laptop power and fan problems
Your machine is overheating. Try cleaning the vents with a can of compressed air and making sure the heat sync is free of dust. If that doesn't work, you may need to replace the fans.
Jun 07, 2008 | Compaq Presario R3000 Notebook
Presario r3000 shuts down
I have experienced similar problems. I found that if the fans were REALLY dirty, the system would overheat and shut down with no warning.
May 04, 2008 | Compaq Presario R3000 Notebook
Laptop won't stay on
it might as well be a internal problem related to power or loose contacts with RAM or the power chords internally.
Better to go to the technician in this case.
Your first Battery would have been fine too..
Apr 12, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Black Screen with flashing cursor
Lines are the BGA RAM Or VRAM Needing rework.. This will also cause boot issues on these models. Do you ever see the Compaq Logo? Weve repaired a ton of these and class settlement happened for the R3000's regarding the jacks but we could repair the other issue as well. (As well as install a new jack while its here).. HP's reimbursing for these outside repairs.
Feb 01, 2008 | Compaq Presario R3000 Notebook
No display
Re- boot the computer, see if it will come back on again.
Go to start- click on log off -than click on restart it will shut down and back up again .
If this dont help try going to re-store - go to the calendar click only on 1 of the high lighted areas , Should put ya back on.
Nov 29, 2007 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
290 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
