Question about EliteGroup 661GX/800-M (661GX800M7) Motherboard
MOTHERBOARD CONNECTION WANT TO CONNECT THE POWER LED-, POWER LED+, RESET SW, POWER SW TO THE MOTHERBOARD SO AFTER CONNECTION, TRYING TO SWITCH ON THE PC COMES ON BUT THE SCREEN DOESNOT COME ON. SO PLEASE HELP.
  • Anonymous Apr 22, 2009
    same as above
  • 625 Answers
Substitute a known WORKING video card and try it.
Posted on Dec 07, 2007
    Sniper:
  • 51 Answers
First double check your connections very closely, preferrably against the motherboard manual if you have it. if this is correct, then double check that your monitor cable is seated in the video card connector firmly, if you still have no video you might want to check that all your components are seated firmly into the motherboard. hopefully your board has not been zapped.
HOW TO CONNECT POWER LED HDD LED RESET SW POWER SW IN BIOSTAR AMD N68S+ MOTHERBOARD
You can find the manual here: http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=498#dl The board is usually marked, also, although it is very tough to read the small print.
Oct 31, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
Int sw
Green and white is normally the power LED connection, as I recall. I may be wrong. Anyway, you need to trace the path of the wires back to the case and see what it's attached to. You normally will have a power switch connection, a hard drive LED connection, a power LED connection, a speaker connection, and possibly a reset switch.
Jun 05, 2012 | ASUS A8N32-SLI Deluxe Motherboard
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 28, 2011 | Computers & Internet
I am looking for the mother board connection diagram so i can connect the towers front panal ie power switch /reset ect
Connect the front panel leads to the motherboard connector marked "JFP1" using the following pins as indicated by the markings on the motherboard and the front panel leads: HDD LED on Pins 1 and 3; power LED on Pins 2 and 4; reset switch on Pins 5 and 7; and the power switch on Pins 6 and 8.
Good luck.
Mar 03, 2011 | MSI 865GM2-LS Motherboard
Please I need a picture or pictures of how you connect the cables from the cabinet in this motherboard GA-G31M-ES2L. the office that I'm trying to enjoy the positive it has entered a msg on the board and...
> HDD LED == hard-disk drive Light Emitting Diode (a "lamp" that lights-up when you are reading/writing files to/from your disk-drive)
> RST SW == the (optional) "reset" switch/button on the face-plate
> SPK == the internal PC loudspeaker
> PW SW == the power on/off switch/button on the face-plate
First, connect the "PWR SW", so that the ON/OFF button works.
It's much less important that the other wires be connected.
For example, if you never press the RESET button on the face-plate, you don't need to connect that button to the motherboard.
Oct 22, 2010 | Gigabyte GA-G31M-ES2L Motherboard
How to connect jfp 1
go to www.msi.com.tw for MSI guide , it should show you your motherboards front panel intel connection guide , it should be like this
PSWITCH PLED Open
RESET HDD SPK
Jun 08, 2010 | MSI G31M3-L V2 Motherboard
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
KM18G pro motherboard power connection, reset sw, power sw, etc.
Hi.
You can download the manual for your motherboard here.
Inside you will find information of where does each connector go. Each connector on the case has a marking on it (HDD, PWR, RST or similar) which stands for hard disk LED, power button, reset button and so on. Connect it to the right place, and problem is solved.
If you need any further assistance, feel free to ask.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 18, 2009 | Albatron nForce2 KM18G Pro (KM18G PRO 2.0)...
EliteGroup 661GX/800-M (661GX800M7) Motherboard Logo
173 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
