Question about Canon NP 6050 Copier
Canon NP6050 Error code E013
When I open this morning my Canon NP6050, I encountered an Error 013. It instructs to turn off and on the machine, but the error still there. Please help me to solve this problem.
  • Anonymous Jan 31, 2008
    I have same problem again and again
    I go in menu & press * 4 * remove error but after some copies it again occurs.
    Second thing is that there is a sound like cut cut
  • lolith May 14, 2008
    E013 stang av strommen och satt pa den igen
    Habit-Forming:
    Scholar:
  • 47 Answers
E013 refers to the waste toner receptical being full, but in this case the toner melts at the end of the worm screw assembly causing the cleaning unit to block up, activating the microswitch which tells the machine the waste toner bottle is full. The solution is to try to free up the worm screw assembly, failing that, replacement of the drum cleaning assembly.
Posted on Apr 15, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Follow this link to either 1st or 2nd error codes link
http://checkitright.spruz.net/main.asp?page=dp&dis=834222
Posted on Dec 07, 2007
I have an error in my machine canon np 6050 with code number is e004
Posted on Apr 23, 2010
My Friend
I will give you the solution
First remove the back cover
You will find a black tube which leads to the toner waste cartage
and inside this tube there is a spring
you have to move this spring inside and outside many times
and it will remove the waste toner
then go in menu & press * 4 * remove error
then the machine will be so good
Posted on Jan 09, 2010
How do i solve an error e000-0000 canon ir 2202 please
Open the front door before turning it On. Leave the front door open until you have either carried out the instructions about clearing the error. OR close it once you have gotten into Service Mode.
Try a service mode reset, abbreviated as follows:
Service mode - Copier - Function - Clear - Error - then restart machine.
There is no detection that your fuser is warming up. Warmup should only take about 8 seconds. If a restart does not fix the problem, the fuser may need replacement.
http://support-asia.canon-asia.com/?business
Mar 04, 2015 | Canon Office Equipment & Supplies
I own a Canon Image Class MF 4550 d. This morning
Try turning the printer off and back on. If this does not work, try rebooting your computer. Another choice is to go to the Control Panel > Programs > Unistall a Program and delete the printer's software, reboot your computer and re-install the printer's softwre.
If this does not work, you can always return your printer for a full refund or ask them to exchange it for a new one.
Sep 07, 2013 | Canon I-Sensys Mf4550d All-In-One Laser...
E0210 np6050 machine
This is an error for the scanner not going to home position. My experience has been that the scanner motor that moves the lens to the left has a broken/cracked gear and the whole motor will have to be replaced.
May 04, 2011 | Canon NP 6050 Copier
I want to get some help about canon np6050 error
Hello jig,
I wish to help you quickly as you are down. I dont have immediate access to the older analog service manual and Canon no longer keeps it on their website.However, E005 has been a common error code for many products, if not all. It means that the cleaning web (which is an item that is "used/consumed "normally as the copier is used.) has run out.The copier should have been diplaying (in small letters on the dispay) "WEB LOW" for quite a while.It needs a new cleaning web.An untrained end user could change this but without instruction most people would not be able to. Its located in the fuser area onder a yellow cover. I bet you can do it !
Apr 09, 2010 | Canon NP 6050 Copier
I have ir 3100 N the error is E 013 please if i
You should empty the waste toner bottle ( open the front door, the bottle is in the middle of the copier, you have to unscrew the small piece of plastic on top of it, remove it, remove the 2 small plastic pieces on each side of the top of the bottle, clean it, empty the bottle, clean it, put the 2 plastic pieces on it, put the bottle back inside the copier, ON / OFF the copier and it ll works :)
Reagrds, Mug71
Sep 14, 2009 | Canon Office Equipment & Supplies
System error E000 how do I fix it. I tried what it said in the instructions to turn it off for a while then turn it back on that didn't help. Canon NP6025 copy machine.
To delay the 3 second shut down and enable the technician to access service mode; open the front door and pull out the transport unit. Do not actuate front door microswitch. Press the service mode button, enter " * 4 * ", scroll to error clear and clear error code. Machine will automatically turn off power after clear. Power up machine and test.
If the power shuts down after error code has been cleared, the cause of the error has not been corrected. Correct cause of error code and clear error in service mode.
May 07, 2009 | Canon Office Equipment & Supplies
E 005
A E005 is saying the cleaning web needs to be replaced or the web counter needs to be reset...If the cleaning web is out it will cause more damage to your upper fixing roller
Jul 28, 2008 | Canon NP 6050 Copier
Error code e002 on canon copier np6050
Also this code needs to be cleared in service mode. Despite what the display says, turning it off and on will not reset it. To enter service mode insert a straightened paper clip into the small hole in the front cover, near the meters, a "$" sign will appear on the display. Press * 4 * in order. Press ">>" to select "error" then press "OK" then power cycle.
(I cant remember on that model but you may need to defeat the interlock on the front door in order to enter service mode.)
Jun 02, 2008 | Canon NP 6551 Black and White Copier
E0004 on Canon NP6050
it is a SSR,heater 1 or 2 ,or thermal switch error.   Try to reset,        follow this procedure. SERVICE MODE E004 SSR O FUSER WON´T SHUT OFF
To reset this code use simulation 401
SERVICE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck     CE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck
Oct 24, 2007 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
1,532 people viewed this question
old marine
old marine
