Question about HP OfficeJet 5110 All-In-One InkJet Printer
My all in one hp printer dosent load paper
My printer dosent want to load paper from its tray to print! it just makes funny noises!it does recieve faxes ,there is ink there are no paper jams it just says load paper?
Dear
This is the common problem of this printer;PROBLEM WITH SERVICE STATION GEAR(SMALL) ;IT MAY BE BROKENED ;
rGDS
jigin
Posted on Dec 07, 2007
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
Keeps saying load paper, paper is in
Are the rollers worn out? If they have a slick appearance, that is your problem. Also examine the tray and see if it is lifting properly.
Sep 30, 2017 | HP Photosmart 3310 All-In-One InkJet...
My hp laserjet 3005 does has paper loaded in try 2 but always prompts me to load tray 1 to print. I would like the printer to print from tray 2 when it's loaded and try 1 is not loaded. Thank you.
Thank you for contacting FixYa with your printer inquiry.
This is a common problem. The device can be set to print from tray 1 if it is loaded, or to print only from tray 1 if the type of media selected is other than standard bond.
Pull out tray 2 and make sure the paper size adjustments are properly set to match your size of paper. If you are using std bond and the adjustments are set to A-4 it won't pull paper.
HP Control Print Jobs Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=1846088&prodTypeId=18972&objectID=c00764862
HP Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00764851&lang=en&cc=us&taskId=101&prodSeriesId=1846088&prodTypeId=18972
Hope this helps helps. Please keep us updated and remember to rate this answer.
Sep 02, 2010 | HP LaserJet P3005 Printer
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
Printer will not kick out document automatically, attention lite keeps flashing. tray 2 selected but always defaults back to tray 1
Sounds like you have a mismatch in the paper you are trying to print on and the paper that is loaded in the printer. HP printers look to feed paper from tray 1 anytime the computer settings don't match the paper loaded in tray 2. Tray 1 is the multi purpose tray and prety much any size paper can be loaded in tray 1. Double check your document settings and double check the paper size loaded in the paper tray 2 and make sure they match. Also try printing a different document to see if the error persists. If it does this on everything you try to print you should also double check teh rear guide in the paper tray. There is a rear guide in paper tray 2. If it slides back too far it will make the printer think that paper longer than 8 1/2 x 11 is loaded. Push the paper all the way forward in the tray and push the rear guide until it is snug with the tail end of the paper stack.
Nov 01, 2009 | HP LaserJet 4700 Printer
Printer making crunching noise when printing. trouble picking up paper from main tray. keeps asking for paper to be loaded in tray, when its full. help D
It is a hardware problem.Your printer roller & paper sensor are not working properly. So pls checked it from service center
Oct 13, 2009 | HP Photosmart 3310 Printer
I print a publication so I print many copies within a few days. It says Paper Jam in tray area but I can see no paper, it makes a noise and never feeds the paper.
Some Laser printers require the paper to be loaded out of the **** on one side to work well. Flip your paper **** over and try loading the paper upside down. Sounds funny but may fix your issue. Also look at the type of paper you are using your printer may need a thicker or thinner paper (look at the manual). Clean the pickup rollers!
Jul 07, 2009 | Samsung ML-2510 Laser Printer
Load Noises
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at
http://www.hp.com/support .
Feb 15, 2008 | HP LaserJet 1320 Printer
HP OfficeJet 5110 All-In-One InkJet Printer Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
