Dear ALL
Facing problem with HP ALL-IN ONE PRINTER 3380;
Description: After powering on SCANNER BULB WARMING UP screen will come,2minuts latter the error is comming;
I confirmed scanner cable-ok;what may be the problem;pls give me some tips to solve the problem
  • 1 more comment
  • jigin Dec 07, 2007
    Thanks for replay;
    actually i already tried by cleaning lense and mirrors;after that it works for some hours;but again after restarting, the problem is comming (intermittently),what may be the other causes.pls
  • jigin Dec 12, 2007
  • audrey110 Jul 06, 2008
    My copy function has decided to break down and I do not know why. When I press copy, the error message I get is 'device is busy try again letter' and then it defaults to scanner error and the cancel button just blinks orange until I print. What should I do to get the copy function working again?
  • 208 Answers
You may want to remove the glass and clean the underside of the glass and the lamp, also whatever mirrors and lenses there may be. It sounds like it is not setting up properly and the glass and mirrors getting hazy can cause that.
Posted on Dec 07, 2007
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
Why would my scanner not work on my laser jet 3380 all in one printer?
If you are getting scanner error it is time to clean the scanner assembly.To do so you are going to need proffesion help beacause the scanner can be damaged easy .This error is verry common for the HP all in one printers.If you need any futher help pls replay. Vote if that was helpfull.
Oct 27, 2010 | HP LaserJet 3380 All-In-One Printer
Hp laserjet 3380 - MS Vista - scanner error, copying is ok
clear glass, replace ribbon scanner cable if no result - replace scanner
Aug 24, 2009 | HP LaserJet 3380 All-In-One Printer
The panel on my laserjet 3380 says scanner erroe power off power
You need to clean the small mirror film. Repeatedly turning on and off the printer will move the scanner head to the left. When it makes it to it's final position remove the screw and using a qtip gently wipe the thin mirror film next to the light bulb. This will clean the dust that is causing the error. some say use alcohol on the qtip i never used it. Once it's clean the scanner will return to it's original position and resume function. return side glass and screw, and you should not have that error until it's once again dirty.
Jan 17, 2009 | HP LaserJet 3380 All-In-One Printer
Bad fuser Laserjet 3380
is u 3380 fuser fixing film ok...if ok try to change presure below fixing can take out the fixing firm or presure roller.just check the size only.if same u can combine it.
2.try to clean paper pick roller at 3380 printer..
Nov 11, 2008 | HP LaserJet 3380 All-In-One Printer
Scanner problem
Not sure about a mac, but on windows you have to have the HP toolbox running.
Sep 02, 2008 | HP LaserJet 3380 All-In-One Printer
Scanner Error - Power On > Power Off
Sounds like the scanner has died. Sometimes restarting can help out. If you can print try printing out the configuration page and let us know what the error codes are.
May 27, 2008 | HP LaserJet 3380 All-In-One Printer
HP 3380
It needs a scanner assy.
Dec 05, 2007 | HP LaserJet 3380 All-In-One Printer
1,009 people viewed this question
