Question about RIM BlackBerry 7290
Device stays on GSM
When the device is in a very weak or no signal area for a long period of time, it only comes back on to GSM when returning to a good signal area. I have to do a hard reset on the device to get it back on to GPRS. Anyone know why or how to overcome this? Many thanks.
  • Aaron Prentice
    Aaron Prentice Dec 18, 2007
    Yep, this used to happen to mine all the time!
    & it used to SCREACH down my ear before connecting a call.
    Orange gave me an upgrade.
  • bw65587 Jan 07, 2008
    Yeah, this is what I have had to do previously or a Alt + Shift + Backspace reset. Just had to do one now as a matter of fact. I will look at upgrading the software. Thank you.
  • 44 Answers
You may need to upgrade software, but if you have a sim card pull your sim card and battery leave them out for a couple minutes, put phone back together and see if it resolves your issue, could be a glitch in the network.
Posted on Jan 06, 2008
What can i do to stop from going back to homepage every five decounfs while im browsing the net
While clearing the cache and checking your network settings are excellent suggestions, if they DO NOT resolve the problem then it is likely you have a weak or bad connection to your Internet provider (either the cellural data link and/or the WiFi link). This can occur due to a weak or intermittent signal or due to strong signal interference. I suspect the latter because you seem to be able to connect easily (indicating at least a good initial signal), but then it abruptly drops. Interference can come from many sources (motors, microwave oven, competing radio signals, nearby electrical lines, or a neighbor's WiFi signal on the same frequency and channel, etc.) It can also be caused by other devices on your own network such as a satellite box, a printer, or a streaming device that also connects to your Internet provider's signal.
A simple way to troubleshoot WiFi interference is to look at other ambient signals. Download an app called WiFi Analyzer from the Google Playstore. Run the app and very slowly move around the areas where you access the Internet. All measurable ambient signals will be displayed, including your primary signal, with their channel and relative signal strength. If there are others that approach or surpass your primary signal on the same channel, then WiFi interference is a likely source of your problem. The fix: change your router's signal to another (unused) channel. This is done by entering the router's setup routine and modifying that setting (usually at an internal URL address at or similar to http://192.168.1.1 - the exact URL and directions are on the documentation that came with your router or on the manufacturer's website).
The WiFi Analyzer may well identify the problem. But it will not identify other local sources of interference nor a weak primary signal, such as mentioned above. But changing the router channel may still help.
Or, you may eventually need to invest in a better router (N or AC protocol, and dual frequency) and/or switch to another service provider with a stronger signal in your area.
Jun 06, 2015 | HTC Desire Cell Phone
Samsung reality won't stay connected to jabra bt2046
I've had this issue with lots of Jabra products, including both my BT3030 devices. The problem seems to stem from the quality of the charge. When the device is fully charged, it seems out a nice loud clear signal which can be detected by your phone. As the charge begins to wake the signal gets noisier. So (my experience shows), When you pair your device with a clean signal, that's what your phone is looking for. If you pair with a weak signal; it looks for that. The ideal seems to be too pair the items up when your bluetooth device is either fully charged, or mostly charged.
Think of it this way. You meet and are introduced to a strange man in the early morning who is clean shaven. You meet the same man a few days later with lots of stubble and fall to recognise him. It's a bit like that!
Feb 18, 2014 | Samsung Reality U820
Roxio VHS to DVD 3 worked great for 10 projects; now I cannot get a good video signal. Sometimes I get an intermittent weak and distorted signal. Audio is clear. I bought a new VCR player, and returned...
I keep the heads clean by opening the vcr and using clean white paper pressed on the cylinder head spinning the head with your other hand. Also back in the day... you had to buy a device to go between two vcrs to prevent the copy prevention of the time (blurry copying)
Oct 15, 2013 | Video Cameras
How to get rid of static
Your radio allows you to listen for weak signals on
the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press MON button. The RX
icon blinks.
• Press and hold MON button for 2 seconds until
two beeps sound for continuous listening. The
receiver circuit stays open, letting both the noise
and weak signals to be heard.
To turn OFF Monitor Mode:
Press MON button to return to "Normal" mode,
and the RX icon stops blinking and disappears.
Dec 28, 2011 | Uniden GMR22382CK Two Way Radio
I want to tap RPM signal for a new tracking device I am installing. Where can i find the wire and what is the colour of the wire
This signal wire can be taken directly from the back of the dash panel...it is the green/black trace wire. But you should follow the circuit on the back of the panel to ensure it goes to the RPM + SIG. circuit.
Also make sure that the device you are connecting can pick up the signal coming from the panel as some ignition system signals are very weak and the device my not be able to pick it up.
So let me know how you get on.. Thanks
Jason
Jun 10, 2011 | 2010 Hyundai Elantra
Satelite connection very weak, takes very long to connect, losses connection very easy, then take a very long time to reconnect, basically rendering this device useless on trips
I had the exact same problem with my 1300. Even used the word "useless" to describe its functionality. After every software update and reboot, etc. the signal strength never improved, even on a clear day with the unit outside my vehicle. Unfortunately, the only solution offered by Garmin online support was to return it. Email them and describe your problem, and they should give you a Return Material Authorization number and instructions. Haven't gotten mine back yet, so I can't tell you if they really fixed it or not.
Jun 15, 2010 | Garmin nuvi 1300 Car GPS Receiver
Nokia n70 does not show 3g icon
The 3G icon appears only when you are in 3G reception area and you are receiving 3G signal.
Ensure that you are in the 3G reception area and signal is received .some areas there may be weak signal it may also cause to select Gsm mode
May 28, 2010 | Nokia N70 Smartphone
Zyxel G-220 will not connect after a period of time.
The issue you are facing is very common in nature. The issue can occure due to many reasons. Since the wireless access is related to frequency which again is sensitive to other devices which work on the similar technology like Microwave Owen, cordless phones etc.. All wireless devices which transmit signals have an option to change the frequency in which the signals are transmitted - hence all you need to do is access the setup page on your device (through a wired connection ofcourse ) and change to a different channel (generally the range is between 1 - 11) under the wireless section. Make a note of the name/ SSID you have provided to the device. Save the changes. Now unplug the cable between the computer and the device. On your computer search for the network and once found select and get connected. Now since its the first time. It might take some time for you to identify the right channel but since this task of finding the best channel is done only once. I guess its worth the effort
So to conclude - changing channels could reslove your issue
Nov 08, 2009 | Zyxel G-220 802.11g/b Wireless Adapter
Bad wireless network conection?????
It could be because of a few issues. The signal from the wireless router could be too weak, try moving closer to the source of your wireless access. The wireless adapter could be faulty. There could be something in the area that is interfering with the signal (another device running on a similar frequency).
Mar 24, 2009 | Toshiba Satellite M35X-S109 Notebook
Device is inoperable
I've had the same problem since the first time I tried to turn it on. I have to press the on button 20-25 times over a period of 5 min. to get it to work.
Feb 01, 2008 | Brookstone Pure-Ion (506840) Air Purifier
RIM BlackBerry 7290 Logo
46 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
