Toshiba Satellite A1O A15 A20 A25 A30 A35 A40 A45 Series 15 inch LCD Display LQ150X1LHC3 CD-ROM Drive Logo
Posted on Sep 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im Having trouble getting the back cover off a Toshiba Satellite A30 I need to get to the power prong to replace it and the cover seems to be not coming off
Anonymous
Level 2:
  • Expert 211 Answers
  • Posted on Sep 02, 2009
Anonymous
Expert
Level 2:
Answers
211
Questions
0
Helped
147164
Points
736
Here is Toshiba Satellite A35 (which is the same as A30) disassembly guide.
Just follow instructions by scrolling down, then go to page 2, 3, 4...
How do I restore my Toshiba Satellite A30 303 back to factory settings.
press power on button and press F2 to enter BIOs
in last select restore to factory setting and save changes by click on link or press F10
3answers
The power jack is broken and I need to replaced it. I have one available now but looks like I need to remove the mother board from the laptop. How is that done?
with great difficulty, you may be in luck and find an online guide with video on youtube.
There is a service guide for the A30, this should help with stripping the laptop, it takes a while to load, http://tim.id.au/laptops/toshiba/satellite%20a30.pdf
3answers
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. [email protected] for any additional questions.
Need take down instruction to fix a35 power addapter
Hello there:
if you do a google search
toshiba satelite a35 dissasembly instructions
there will be a big section on these laptops so make sure you get the right ones ok?
best regards mike
My Toshiba Satellite A30 laptop keeps switching off when charging. It works fine when on the battery but seems to overheat when I use it whilst charging the battery. Can you help ?
I would suggest that you try it with another AC adapter first, because it seems the adapter is faulty and therefore supplying more current into the laptop than necessary.
If it works perfectly with another AC Adapter, then you might just have to change your AC Adapter.
Hope it helps.
A70 recover disc in A35 Laptop? (Toshiba Satellite)
Recovery disks are model-specific, mainly because they have different devices and drivers. Setup drivers are downloadable, and copied to a CD at an Internet cafe.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
