Connecting a mikomi 3 button optical mouse to a packard bell pc
I have tried to connect a new wired mouse in a usb port but the wizard informs me that the product software is not licenced, I tried to continue anyway but my pc crashed. I have now restored the old mouse. Do I need some sort of driver for the new mouse?
  • mrmad Dec 07, 2007
    No the mouse was probably made in the USA !!!
    Scholar:
  • 152 Answers
If you are using windows XP its not necessary since it already has built in lots of generic drivers..
i bet that mouse cost you like 2 bucks or something.. when things are too cheap they tend to fail quickly..
Posted on Dec 07, 2007
How to setup ge 99916 wireless mouse
Instructions
    • 1Hold the mouse in your hand, press down on the battery compartment cover (the back of the mouse) then slide it off.
    • 2 Insert two AAA batteries into the mouse. Make sure the positive and negative terminals match up with the diagrams inside the battery compartment.
    • 3
    • Replace the battery compartment cover.
    • 4 Connect the USB receiver to a USB port on the computer. The computer will acknowledge that a new device has been installed and you will be prompted to install the software.
    • 5 Insert the software installation disc into the optical drive. Follow the instructions provided by the installation wizard to install the software.
    • 6 Press the link button on the receiver, then turn the mouse over and press the link button on the mouse. The mouse is ready for use.
Jun 07, 2014 | GE Wireless Optical Mouse
Usb optical mouse not working
If wireless, replace the batteries. If wired then make sure it is not on a reflective surface and try connecting it to a different USB port. Otherwise mouse could be dead.
Feb 12, 2014 | HEWLETT-PACKARD Probook 4530S
I cannot get my new optical mouse to work. GE98548. I have the USB receiver plugged into the USB port, pressed the button and the red light came on. I pressed the Connect button on the mouse and nothing...
Hi
Basics first (some or all of which you may already have considered).
I assume you have batteries in the mouse.
Check the manual for the correct sequence and procedure for introducing the mouse to the transdponder for the first time. Sometimes the buttons on the wireless transponder and mouse need to be pressed and held for a certain amount of time.
Sometimes there needs to be clear line of sight between the mouse and the transponder, depending on if the signalling is Infra Red or RF. Consider a Male to Female USB extension cable that allows you to plug the male end of the extension cable into the PC's USB socket and the transponder into the female end of the extension cable, enabling you to place the transponder in clear line of sight of the mouse.
You will know when the mouse is properly connected to the transponder because when you press the Connect button the transponder should blink in response.
Leaving the transponder connected to the PC, try connecting a wired USB mouse to different USB port to see if you can get a moving cursor with it. If the Hardware Wizard appears, you may need use it to install USB drivers that are already in windows but not yet installed and active. After this, disconnect the wired mouse and test the wireless mouse again.
Also check in your BIOS (see which key to press - often DEL or F2 -during boot from the menu at the foot of the first boot screen to enter BIOS Setup and check if Legacy USB function is on or off. If off, use the + or - (or sometimes page Up or Page Down) keys to toggle it to on > F10 > Enter > boot into windows and test USB wireless mouse again.
If none of these ideas solve the problem, the device may be faulty and should be returned under warranty.
I hope this helps.
Aug 24, 2011 | GE Wireless Optical Mouse
Wireless Logitech mouse with NO connect button on it. Only buttons on it are Power and Reset (and one to open battery case). Cannot figure out how to connect to receiver. Was previously connected, but I...
Ok, try this in the steps ordered
1 remove the receiver from the USB port
2 remove the battery from the mouse
3 turn on the pc
4 after everything is loaded on the pc, plug the mouse receiver into the USB port
5 put the battery back in to the mouse and let it "find" the receiver.
If these steps don't work, try doing the steps and use a different USB port. If that doesn't work try a different battery in the mouse.
If none of this works and the receiver hasn't been bent (happens allot in laptops), then it sounds like your mouse took a dump.
Mar 18, 2010 | Logitech Cordless Mouse
I just got a new mouse, and last night when I
try to do these things:
1. press the black link button on your puck or key that connects to the PC usb port.
2. turn the only switch on the bottom to ON (to the right)
3. press the link button on your mouse on the underside.
4. double left click your mouse to make sure it will wake up and run
5. check it on another USB port
6. look for damaged pins in your usb port on the laptop
Sep 24, 2009 | GE Wireless Optical Mouse
Microsoft Optical Wireless Mouse 3000 MSK 1056 does not work !
I fixed an MS wireless mouse that was not responding by pressing the button on the receiver while it was connected to a USB port & then pressing the button on the mouse. Worked fine after that.
Dec 23, 2008 | Microsoft Wireless Notebook Optical Mouse...
Mouse broke on pc so brought another, and another, but same problem at the end.( found new hardware - unknown device. windows found driver software but encountered a problem installing it) hav now bought 4...
drivers required for mouse operation will be provided in windows itself so u can try connecting your mouse via USB port(except ball mounted mouse)better use optical mouse ...even after this if it is not working then you need to reinstall the OS.
thank you..
Oct 31, 2008 | Computers & Internet
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Sep 18, 2008 | Microsoft Wireless Optical Desktop Comfort...
How can i remove the hard drive from my packard bell club 79 computer?I have some pics on there i would like to put on my new pc but the old packard bell no longer connects to the net and as it had win98...
If you have a router with two thernet ports you can connect them together using this.
Otherwise you can take the hard drive out and connect it to your new computer but this can be tricky to do.
The other thing you could do is buy a USB hard disk caddy. Fit you hard drive into this and then connect it to the USB port of your new computer. Make sure the caddy will take your size and type of hard disk.
Aug 17, 2008 | Packard Bell Computers & Internet
Took mikomi am-2210 mouse out box ,connected it to usb and it lit up but would not do anything,neighbour also tried it on his computer
Then you have to try the convter for the usb mouse. the converter are available for the usb mouse into serial port. just get the converter of the usb into serial port .try it inform to fixya.com
May 12, 2008 | Computers & Internet
Computers & Internet Logo
106 people viewed this question
Alun Cox
David Payne
David Payne
