Question about Motorola Mobility RAZR V3x Cellular Phone
Motorola v3x - critical error 84
Unlock process didn't work. I was advised to restore backup (Flash & Backup) and try again. Unable to restore - Halfway through restoring the first file, it shuts the phone connection down. Screen shows "error" against all files. Phone displays critical error 84.
  • 1 more comment
  • Anonymous Jul 13, 2008
    I have exactly the same problem.
    Have you solved it?
  • nbalee83 Nov 25, 2008
    I have to this problem!
    Moto v3r
    "Critical error 84"
  • Anonymous Mar 30, 2014
    When switched on screen flashes file error restore default
No i have not
Posted on Dec 30, 2007
Runtime error with EZ Backup restore
Did you try to reinstall the EZ software? perhaps you accidentally removed (a part of) a program.
Then try to restor the data again.
Jul 08, 2014 | NTI Backup Now EZ
Tip
How To Remove a Restart Problem when Phone Imei is oK but Phone goes on to...
Inthis case first try to solve this problem by only Write Full Modified (Without308 Field) PM With
SX4 Auth.Use SX4 and when it done Successfully then immediately Write supportedfull modified PM to the phone and check phone without MMC, problem is fixed ornot, if not then Full Flash and after that Write PM with SX4, or try to solve
by Downgrading.Oftenly Restart problem is removed by only do File System Formatand Factory Default. (Check
phone without MMC) Otherwise there is only one way is left to Repair it with Software and that
is Erase Flash (Rap), to start the Erasing Procedure,
Follow thisgiven below Method:
Before StartErasing Flash, Save your both backup PM 308 and RPL backup (CRT 308 and CRT
BKP)If you are going to do erase newer BB5 + (Plus) Phone then you must Savealso Full PM 0 to 400
Backup, coz you will need it for restore the orignal field 308, this is reallyfast easy and perfect
way to restore the PM 308 Field, otherwise you may need to buy an new RPL.So be careful. . .
Now we are ready to do erase.SelectUNI_rapido.bin in Mcu Part and click to Flash
and for MT Select uni_rap.bin as MCU.
when phone will fully erased then Phone Imei will be: 12345610654321, SP Areawill damaged
and CMT Flash Data will shown: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Now Full flash with any Firmwarever but selected firmware should be not too Old or too New,
coz we may need it in another case.After Flash when phone will turn On, youwill get
damaged IMEI: 12345610654321 and Courpted SP Area:
PROVIDER KEY: 0000000000000000, Provider: Unknown provide
Now first of all you have to Restore the Orignal backup of PM 308, in case whenyou are unable
to restore the PM 308 backup then flash again with same FW when you were takebackup.
When it flash successfully then plz stay a min and write it (PM 308) back tothe phone, now
Disconnect phone, connect it again and see SL Zone is Repaired or Not.
(It should be repair now), if not then flash again with same FW and restore thePM 308 backup.
But if you have Full PM 0-400 backup then no need to Flash again, just Write it(Full PM 0-400
backup) back to the phone without SX4,when it done successfully then removecable to the box,
replug cable and get info you will see SP Area is Repaired now, if not then itwill be repair after
writing RPL backup.
After successfully restore the PM 308 backup phone will on ContactService/Retailers or full
working phone with damaged Imei. In this condition when phone has damaged Imei:
12345610654321 you can write full modified PM
(without 308 field) without using SX4, coz phone has not certificate (IMEI),therefor no need to
use SX4.Now we have to Restore RPL backup. If you are using JAF then Click onCRT Tool, now you will
see BB5 Certificate Tool Window
tick on Write RPL Option and also mark onPlain RPL box, now Select your RPL backup and
click on Write RPL button.Get info now and see Imei is restored succcessfullyor not phone
should be on Contact Service/Retailer or fully working. . .
But if you are failed to restore the RPL backup, i mean phone Imei is stilldamage and phone
show only Nokia and then shut Off in case now you Write blank_rpl and Flashagain with Latest Firm Ware.
When it (flash process) done successfully then write RPL backup, get Info andsee Imei is back or
not, it (Imei) should back now, and your Phone will on ContactService/Retailer, if Not and you
got dead phone Please follow again all above erasing method.
Finally use SX4 and Write PM Field [1] and [309] (or full pm as you wish), nowwe have done all
abt Software.I think That's all. . . abt BB5 Repair with Erasing Method and wehave confirmed
now, phone has Software Problem or not.
on Apr 26, 2011 | Cell Phones
Unable to restore from system backup
Try AOMEI Data Backuper, a free backup and restore software. It can help you restore from the backups. http://www.aomeitech.com/aomei-data-backuper.html
Dec 16, 2012 | NTI Backup Now EZ
Back up error.....i need more help please
check out this link for the solution.
http://www.pagestart.com/win7br0x8100003301.html
Dec 28, 2011 | Acer Aspire AX3400U2022
I can't unlock my phone Nokia N97 is there any trick that I can unlock it??/ I can't even switch it off and also tried the trick with the battery out it didn't work.....
JUST GET U R PHONE FLASH UP...BUT BEFORE FLASH PLEASE DO SEE THAT U TAKE ALL U R BACKUP...CAUSE U R PHONE MEMORY WILL BE TOTALLY FORMATTED IN THESE PROCESS AND NEW SOFTWARE WILL BE INSTALLED
Jun 22, 2011 | Nokia N97 Cell Phone
When i try to transffer data to the sandisk sd 2gb card im getting 0x8007045d error help please
it is because your card is formated as FAT ( this means that you can only store small files on it ). To fix this do the following 1. open my computer 2. right click on th sd card 3. press format 4. in format select fat32 instead of fat 5. click format (you will lose all data currently on the card) 6. when it is finished you should be able to copy files onto it
Mar 16, 2011 | SanDisk 2GB microSD Memory Card
How to install itunes again in motorola v3i?
Before you do this make sure you transfer all the info on your phone to a backup disc. Do a MASTER RESET. If that doesn't work the only other thing that I can tell you is to do a MASTER CLEAR. Doing a MASTER CLEAR will restore phone to when you bought it.
May 27, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My RAZR V3X keep crashing while being updated
hi! it seems that you got all the drivers correctly installed! anyway, haven't experience that kind of problem! may i suggest you go to this site c www.modmymoto.com, you can search for the answer to your problem and as well post your problem. it is for motorola phones and all the people there will be willing to help you..
Oct 10, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Help
You chose a wrong version for your phone. Flash your phone with the original version of your phone. Choose Monsterpack flshfiles, which you can see 1FF is written in last. You can get flashfiles from here.:
http://www.letsmoto.com/forumsR/cat73.html
May 19, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility RAZR V3x Cellular Phone Logo
1,804 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
