Question about Garmin eTrex GPS Receiver
Faint screen image
having problems with the image on screen. I can only see the pages very faintly, making the GPS unusable. I can see that the pages can be changed and signals are being picked up. Greatfull for any help
When you first power on using lower right (power) button, wait 6 seconds for the intro screen to finish. The upper left (up) button increases screen contrast. Hold this one down for a few seconds and the screen should darken. The middle left (down) button decreases contrast.
If this doesn't work, try turning off by holding the power button.
Hold down upper left AND upper right while turning unit on. This initiates diagnostic mode and contrast is darker by default. Bottom of screen is a button test area which darkens a symbol for each successful button press. Use it to diagnose a button problem. Turn off power and on again to leave diagnostic mode.
I wish you success playing with the Etrex.
Posted on Dec 20, 2007
Have power but no Display
Bonnin, Can you see a faint image on the screen? Have you tried to hookup an external monitor?
IF you can see a faint image on the screen, and a normal image on the external monitor, you have a bad power inverter (for the lcd screen) or a bad back light (in the lcd screen).
Take laptop to a shop to have them verify.
Hope this helps.
Nov 24, 2013 | MSI Computers & Internet
Hi my sony vio vgn txn 15p video is faint
If when you say faint you mean you can barely make out an image then the problem is most likely the backlight inverter in the screen assembly has gone bad. If what you mean is that the brightness got turned all the way down then it's just a matter of adjusting the brightness of the screen by holding down the function key (Fn) and pressing the LCD screen brightness adjustment keys noted usually by a picture of a sun or something similar accompanied by an up or down arrow.
Dec 09, 2010 | Sony VAIO VGN-TXN15P/B Notebook
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Iam trying to down load our airline tickets .i have replaced my black toner, but when i print out our tickets thay are so faint as to be unusable for presentation to airline check in
If your printer print faintly, and your toners are not low, the problem lies with the imaging unit. What happens as the printer is used, a film of toner builds up on the developer/toner blades. This build up starts to block the toner that ultimately makes the image on the paper.
This can be fixed one of two ways. You can buy a new imaging unit for around $100+ but, eventually the film of toner will build up again and they you can buy another one. Or you can take your imaging unit apart and clean the developer blade(s) and you will be good to go. It will take about 20 to 40 minutes the first time you do it. I have instructions on how to do this in my Tips section.
Mar 04, 2010 | Samsung CLX-3160 All-In-One Laser Printer
Our Laser printer doesn't print on the left had side of the paper--well, very faint--the right side is just fine. I just replaced the cartridge. What is the problem?
If your printer prints like this:
657b300.jpg with the any color printing faintly down the page, then the problem is with the developer blades in the imaging unit. What happens is there are metal blades that meter the amount of toner that gets put on to the drum that makes the image on the paper. The toner is made up of fine particules of plastic. As the printer prints, some of this toner collects on the edge of the developer blades causing less and less toner to make it onto the page making the print look faint.
To correct this problem, you either need to buy a new imaging unit or clean the developer blades. There is a document on the internet that gives a detail instructions on how to do this, but, the link no longer works. I have a copy of this document, I will try to post it if people are interested.
Jan 15, 2010 | Samsung CLP 300 Laser Printer
Dark LCD screen. Very faint image.
Internally it has a inverter board which go bad sometimes or due to heat sometimes get unpluged.So you will have to open it make sure when you do there is no power going to it.Look at the wires make sure they are snug and try again.
good Luck
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Geko 101 wouldn't turn off. Removed/inserted batts, wont turn on
Press the power on button while holding OK until the unit switches on- that puts the 101 into Service mode. Then press the up key until the screen contrast is about right. (or press the down key... to make it darker). You'll be able to see if all the tests pass. Then when you're happy with the setting, turn off.
Mar 31, 2009 | Garmin Geko 101 GPS Receiver
Compaq presario 900 lcd not working, shows faint image
out put connection from the video card to the LCD monitor is loose or malfunctioning. check the connection that leaves the video card to the monitor, ensure its secure and clean, if still not working then its either the video card or the cable connecting to the LCD.
Dec 11, 2007 | Computers & Internet
Garmin eTrex GPS Receiver Logo
187 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
