Question about Dishwashers
Water not spraying on the arms.
Dishwasher is old but has been good. Only recently the water will not spray on the arms and water is sitting in the bottom of the machine and not being pumped out. Please help me as Christmas is approaching!
  • trevpasty Dec 24, 2007
    My dishwasher does not pump water through spray arms, I suspect this is a problem with a pump, can it be tested easily or replaced?
  • need2fixit Jan 08, 2008
    my kitchenaid (18) yrs old but working, draining, cycling filling , drying, just developed the same type of problem, on this unit there is a rubber tube that runs along the top rack and slides into a supply at the back of the machine I had replaced this a while back, this tube is what feeds the water to the sprayer arm on the top rack however I checked it out tonight & that dosen't seem to be the problem the machine will fill go into wash cycle but water is not getting to spray arms it just sits at the bottom until it drains. pump issue maybe? or impeller?
  • 833 Answers
Darema,
This is an issue with the pump or the timer. Hard to know which from here. You can do some testing but it is difficult. First, find the float in the machine which gauges the water level...if it has one. Raise it to its highest height and secure it by wedging. That makes the machine 'think' it is full of water. Can't find the float...first try the tests below at the end of the wash cycle...to make the machine think it is draining the water...still no go...you may have to actually fill the machine. With the power off, remove the cover on the lower part of the machine.
Locate the motor and open the connector to it. If you own a volt meter, with the power back on and with the timer set to midway in the wash cycle, see if there is voltage at the motor terminals. If there are more than two terminals, try white and any color and then black and any color. No voltage... try a couple of other positions where the motor should run...no dice...replace the timer. Don't own a voltmeter, you can use a household test light, available for a dollar or two at the hardware store. Be sure the light you buy is for home use...not automotive.
If there is voltage, you've got a motor issue.
Posted on Dec 08, 2007
Spray arms not working
Hi frustrated in Raleigh,
I understand that the spray arms are not moving or spraying water, even after you have cleaned the screens and arms. What might be happening is you are not getting enough water pressure to the dishwasher.
The hot water line to your dishwasher must provide water pressure between 20 and 120 psi.
Low water pressure may occur when laundry or showers are in operation.
Wait until water use is reduced before starting dishwasher.
If you are still noticing that the spray arms are not moving or spraying water, I would have a local Authorized Technician come out to see what exactly is going on with the spray arms of your dishwasher.
-Best Regards-
Jan 06, 2014 | Frigidaire FPHD2491KF Dishwasher
Does not clean, has gritty film, I have a water softnener, I use lig detergent, when I open mid cycle, water seems to be on booth racks, water is hot, I did lose a metal piece off the bottom arm, would...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 15, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher is leaving a white film on dishes. Tried using less cascade. Washer is about 15 years old. Our water is in the safe zone for hardness, also its well water. Just started this recently.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101 ..
Nov 06, 2010 | Dishwashers
Dishwasher is 16 months old. Recently, it won't get tea stains from spoons or cups and there is a white film on plastics. I have run unit once with vinegar. I tried using less detergent and no change...
heatman101
Sep 26, 2010 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Water squirts out but spin bars don't move
Dishwasher
How to Buy
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jun 18, 2010 | Maytag 24 in. DWD1500A Built-in Dishwasher
Frigidaire built in dishwasher model PLD2855RFC1. Have to wash dishes pretty much spotless prior to using dishwaser. Glasses come out with what appears to be soap residue regardless if powder or liquid....
Dishwasher
How to Buy
heatman101
May 31, 2010 | Frigidaire PLD2855RFC Dishwasher
Frigidaire GLD2445RFS0 dishwasher has developed a door leak
Make sure the lower spray arm ends (there are 3 arms) are snapped together all the way. One of ours had come apart and was spraying water out the end of the one arm. It was enough to "spurt" water past the plastic gasket at the bottom of the door. I snapped the arm back together and BINGO. Free fix.
Sep 29, 2009 | Frigidaire Dishwashers
Water not going through spray arms
possible you have a leak and the bottom tray has water in it. tilt the machine back to 45deg and see if water runs out of the back. if it does, after putting upright, the machine will work - then find the leak!!
May 05, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Spray arms
Sounds like the circulating pump is faulty or the spray arms hav become partially clogged. Loss of available water will stop the spray arm motion.
Feb 05, 2007 | Kenmore 16872 Built-in Dishwasher
Dishwashers Logo
272 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
