Question about Philips Magnavox 51MP392H Rear Projection Television
51mp392h i moved my big screen and now the red is double and the green alsor
  • 934 Answers
Unfortunately it sounds like the convergence amps have failed - either that or they have developed ring-cracks where they're soldered to the foil side of the pc board and moving the set broke loose some of the contacts.. Only way to know for sure would be to remove the signal board and inspect them.. Not a job for the less than qualified... Even techs find themselves confused for not labeling the output connectors to the crts properly..
Your set takes two STK392-120 Sanyo built Ics and upon replacing them it's a good idea to also replace R3159 & R3160 both 6.8 Ohm 1w resistors.
Hope this helps.
Bill
Posted on Dec 07, 2007
My magnavox tv has double letters in both red and green images on the bottom 2 inches of the screen
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
Magnavox tv model 51mp392h/17 words on the bottom are double one set is red other set is green
Thats caused by failed convergence ICs and the 6.8 ohm resistors. You can get the repair kit called the DPTV305 -DPTV345 & MAG01 chassis convergence repair kit which fits your model. The kit has the components and the CD with repair instructions and its available at the following link top of the page. http://tvrepairworld.com/phillips__magnavox_repair_kits
The colors red and green are doubled on the picture? we did the converge manualy and it got alittle better but still double colors
the problem is in the converge circuit.dont let the tv to play like that.the damage is going to grow.call the service on your area
May 04, 2010 | Philips Magnavox 51MP392H Rear Projection...
My magnavox 51mp392h has a convergence issue. the
Convergence is dead.Know how to solders? Must replaced the 2 convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkit.com to buy a convergence kit to repair it ur self.The shop will $300 for the parts and labors.
Feb 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a red and green rainbow double effect on my
No, Ur convergence is dead,require soldering change parts like convergence ICs and resistors.The shop well cost u $300 parts and labors.
Jan 13, 2010 | Philips Magnavox 51MP392H Rear Projection...
Getting a green red effect on the screen shows double
Thats a convergence failure. The DPTV305 -DPTV345 convergence repair kit from www.tvrepairworld.com should repair that issue. The kit contains the components and the CD with instructions.
Dec 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Double red & green lines on screen
thats a connector issue in your LCD, it might be your LCD connector have lose connections check it.
Jul 10, 2009 | Samsung PCN5425R 54" Rear Projection...
Green blured color started at bottom left corner and growing
Based off manufactureing timeline it sounds like you have some capicitors going bad you will need to contact a qualified Service agent for a service call to repair the problem.
Jan 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
Green screen
It sounds as thought the lower light strip has malfunctioned & blown the red/blue LED lights leaving only the green bulb functioning, I would ring the makers repair team for a repair if it's under warrentee or a repair quote, if warrentee has expired, from my personal experience showed me that a new TV is cheaper. I hope this helps.....
Feb 21, 2018 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
