Question about Gigabyte GA-7VT600 1394 Motherboard
PCI Simple Communications Controller
Hi there, could you please help...My motherboard is a GA-7VT600 With Socket_A and I keep on getting the yellow question mark next to the PCI Simple Communications Controller under SCSI and RAID Controllers. I can't seem to find a driver for it to fix the problem.
AND: I've connected a UPS and it works ok, but the software is not picking up the UPS. I am of the opinion that it could be due tot the above problem.
Please v=could you help with a solution or driver update.
Thank you and kind regards,
Heidi
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Posted on Dec 27, 2007
It could also be a scsi or raid device. Just becausne it says communication device doesn't mean its a modem. I installed a serial card and before loading the drivers, I got the same reading in device manager under other devices, " PCI Simple Communications Controller".
Posted on Dec 14, 2007
    Sniper:
  • 51 Answers
It sounds like you need a modem driver, what i would suggest is either going to the computer makers website and looking up the specific model of computer you have to find the drivers for that unit, if listed just try to locate the modem driver for the unit you have, if you have several to choose from you may need to look into the unit itself to identify the type of modem you have so that you can choose the proper driver you need.
Posted on Dec 07, 2007
Pci simple communications controller
please go to this link and download your drivers for your motherboard....you may have to download or install drivers for your hardware addons that you installed as well..
Support For H55M E23 MSI Canada Motherboard The world leader in...
Apr 26, 2014 | MSI H55ME23 Motherboard micro ATX LGA1156...
Hi go to dell site the pci is a modem pug on to the router the pci will go the other usb will be ok if you go on to the dell site and down load the usb ,regards clive
Jan 27, 2012 | Dell Dimension 3100 PC Desktop
PCI Simple Communications controller
Hi, yes you need the right driver, do a google search for the driver, there are many sights where it will be free.
Jul 05, 2010 | Intel Motherboard
My pc shows yellow color in device manager pci
first of all right click on the yellow shield you will get a pop out menu choose update driver if that not help then you have to reinstall your hardware
May 14, 2010 | Gigabyte GA-7VA Motherboard
PCI Slot 1 (PCI bus 1, device 10, function 0)
Hi there,looks like your devices need updates to function correctly,
from devices manager,
select the device with the yellow question,
right click and click on update
even if you have no disk or internet
let the wizard find the drivers automatically
should be preinstalled with your OS XP
go thru your list and update any other question marks in yellow.
Should be able to update the network device on this system and then connect to the internet to finish anything else
heres the link for the Chaintech motherboards
http://www.download-device-drivers.com/Chaintech.php
Hope this helps,Cheers Misterdj
Jun 19, 2009 | Chaintech 9LIF7 i845G Motherboard
your computer need to install the drivers for modem. because the simple communication controller name is used for the modem
Apr 14, 2009 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
Motherboard Simple PCI Communications Driver Code 28 for modem
Hello, Mike.
In case you still need this:
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
Mar 29, 2009 | Gigabyte GA-7VA Motherboard
Need a ethernet controller & pci simple communications controller
Try this link: http://partner.atheros.com/Drivers.aspx
You might be able to find something here.
Mar 14, 2009 | Biostar 945GC-M7 TE Motherboard - v6.0,...
i cannot get the sound from the TV tunercard as the PCI simple communications controller in the device manager is showing yellow question mark
Feb 21, 2008 | EliteGroup 741GX-M Motherboard
Gigabyte GA-7VT600 1394 Motherboard Logo
7,332 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
