Error code problem
Wen i switch on the copier it give me error f-26-3
I am problem with my Ricoh Copier 1035 Machine it displays E402 Error aplz guide
Posted on Jan 19, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
You did not specify what machine????
go to my site under error codes and look for your machine and you will mosre than likely find what it means/
http://checkitright.spruz.net/main.asp?page=dp&dis=834222
Posted on Dec 10, 2007
I have an arrow code f 26 on my duet washer
Drain pump triac failure This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
  • Check pressure switch contacts and connectors
  • Failure of the pressure switch or level sensor can also give rise to this fault code
  • Run test program
  • If failure persists after test and verification of pressure switch, replace main controller
Dec 27, 2013 | Whirlpool duet Washing Machines
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
Error code 26
You have a clog some where
F26
  • Run test program
Front Load Washer Repair Not Draining or Spinning How to Unclog the Drain...
May 31, 2012 | Maytag Washing Machines
I have a canon copier ir 3035, its giving error code E000002-0000, whars the problem?
this error is power related. reset the fixing error by pressing * 2 & 8 then * Go to function, clear, error switch off the machine then switch on
Aug 21, 2010 | Office Equipment & Supplies
Konica 7020 error code f-26-2
Says that it is a PCL connector problem. Look at all of your connections and make sure they are ok.
Jun 24, 2010 | Office Equipment & Supplies
Lock code problem
ur security code has been changed by yourself or someone else, wait 4 hours without entering any other code then try 12345 if still fails then take it to repair shop and ask them to do a factory reset with cable and software.
BR
Jun 09, 2009 | Nokia N73 Cellular Phone
Error code c26 on my Toshiba 550 copier
C-26 code it could be your exposure lamp.. when you turn on you copier keep the document feeder open and see if the lamp turns on...if it turns on and the turn off its ok.
Now clean your white reference guide..it's located under the glass..need to take off exposure glass and clean under it..especially a white strip on the edge of the glass.. NOTE: turn of your copier first then clean after adjustment turn on.
May 22, 2008 | Toshiba E-STUDIO 550 Copier
ERROR E000583-0001
hello give me a call on 07764303923 canon engineer of 26 years
i know what the problem is
advise is free
Feb 13, 2008 | Canon imageRUNNER 7200 Copier
Minolta Konica 7145 error code 26-3
NOT SURE BUT YOU CAN GET SERVICE MANUAL WITH ERROR CODES DEFINITIONS www.precisionroller.com type in your model
Jan 12, 2008 | Canon imageRUNNER 400S Copier
Error Message F-26-3
developer most likely needs to be replaced
Nov 16, 2007 | Office Equipment & Supplies
120 people viewed this question
k24674
jasbo
jasbo
