Question about Konica Minolta magicolor 5430 DL Laser Printer
Firmware Problem !
Hi i've just updated my Km 5430DL printer firmware from Konica Minolta website and rebooted printer. After i rebooted to printer there is nothing on the lcd menu now. Lcd menu is blank.
Status displays that Port is busy.After i restarted printer and pc nothing changed.
What happened to this printer ? I fullfilled the same things when i was starting to update firmware as guide shows . but there is still blank screen on the lcd menu.
  • 4 more comments
  • ercnk Dec 07, 2007
    Thank you very much for your helps nightangel.i m surprised that i take answer on time.
    I would like to say i solved my problem but i m still in trouble with this machine.
    i used v2.0.7 version for update from Konica Minolta website.I m trying to update firmware again but printer is not communicating with pc. I removed driver and reinstalled it again but driver doesn't detect to printer. therefore i can't install driver to pc . I tried another usb and another pc but no avail.
    it continuous to show blank screen )=
  • ercnk Dec 10, 2007
    thank you my friend i think you are right i could be rebooted my printer early.
    the printer status was showing that port was busy when i rebooted it . i waited 10 - 15 or 25 minutes and thought that firmware had completed because i waited so much.. then i rebooted printer when it was still in blank screen.
    i have done all the things as guide shows. but there is something important thing that which is missing in that guide. it doesn't shows that how much time i have to wait and what happens at the end of this process when firmware is updated.
    now sellers advise to me that change mainboard and it costs 350 euros )= it isn't fair.
    Thank you so much for your helps.I appreciated you my friend.
    i had read that guide thousand times before updated my printer.Every step had completed with success as i saw in guide.
    I want you to know that firmware programme showed that update completed then reboot your machine. it went good on pc screen but printer ):
    My friend my printer is new and i printed only one thousand print.After that it showed toner measures low on the lcd screen.I had no enough money to buy original cartridge so I sent printer to refilling centre they sent back it with full measure.Because at first lcd menu showed all the toners %100.And i took perfect images.After i closed and opened printer it showed wrong measures and said install yellow toner.
    Then i decided to use firmware procedure when i saw it at KM wesite.I completed procedure with success as guide shows.
    But lcd was still blank and yellow. I waited approximately 20 minutes nothing changed.After i rebooted printer it lost communication with pc.
    Now printer isnt in guarantee.)))= I don't know what to do. Any advise ?
  • emma13 Mar 18, 2008
    Hello i am french and i have the same problem : " i've just updated my Km 5430DL printer firmware from Konica Minolta
    nothing on the lcd menu now. Lcd menu is blank."
    If you have a solution for me, because i see that this problem was happened 3 month ago for you.
    Sorry for my english
    Emma
  • ercnk Apr 28, 2008
    still couldn't any solution emma )=
  • tarassboulba Mar 18, 2009
    I have the same problem( march 2009). It appear to me that this is not accidental because you seems to follow carefully the given instructions. Have you solved this problem ?
    Is there any solution given by Konica Minolta commercial supports ?
    ( sorry for my poor english )
I'm from germany. A few minutes ago the same desaster happened to me. Because the updater showed "reboot the printer", i did so, but then the printer lcd left blank, and in this moment I remembered that the display had indicated "still busy". The updating was still working in the moment I put the printer off. I think there is no chance to repair this by yourself. No firmware, no connection between pc and printer :'(
Posted on May 01, 2008
here is an older version of the magicolor 5430DL Firmware:
version 2.06
ftp://ftp.minolta-qms.com/pub/cts/out_going/other/5430_206.zip
Best Regards
Thorsten
Posted on Apr 25, 2008
    Champion:
  • 214 Answers
What version firmware you have v2.0.7 ?
Try to update firmware again and read the instructions one more time. Try reboot holding stop button down
Posted on Dec 07, 2007
  • 2 more comments
  • Illar Lumiste Dec 08, 2007
    Try restarting this printer with cover open, then it wount start completly and maybe then it communicates with computer.
    Did I understand it right, that printer LCD screen is blank all the time?
    maybe its a LCD problem, does the buttons work? if you press select 3-4 times the printes should print conf, demo or stat page ?
    Ok, I did a little more research, you have to try all interfaces (lpt, usb, ip/web) if non works, then the printer controller FW is damaged, and you have to take youre printer to service.
    You may have to replace mainboard or interface board, beacause as far as i know there is no way to restore old firmware.
    may it be that you rebooted the printer to early, before it was finished.
  • Illar Lumiste Dec 10, 2007
    i havent read the update manual in 2.0.7, i read it 2.0.8 and there was in bold text: that the display will show update completed, when succesfully upgraded and then its OK to reboot the machine. i'm not 100% how long it take to update, in smaller machines it takes sometimes 10-15 min, before this operation is completed sucsessfully.
    this mainboard cost really that much. maybe you cant tell them, that its just not working, and you can get it fix under warranty or maybe they can find used mainboard or a new printer.
    sorry, thats the way it is.
    well, i suggest talk with service, and ask them nicely to get it done under warranty. Because toner refilling and firmware isn't related. so, the warranty doesn't cover any image related problems, but you have electrical problem, mainboard failure, you dont have to tell them, that you did FW update, just tell them, that one day printer LCD went blank and its not working anymore. Or ask them to look for a used mainboard. or you can get a little discount, if you give them this printer for spearparts, or by a little cheaper printer (MC 2550/ C10)???
How do i fix C-E002?
Hladnc, Go to Service mode, state confirmation, memory/HDD adjust, HDD Version upgraded. Firmware on the control board/image control board not matching data on the Hard drive. per the service manual, if not that bad control/image control board
Jun 03, 2015 | Konica Minolta bizhub Office Equipment &...
Magicolor 5430DL firmware
located at a secure Konica Minolta web site seem that Konica Minolta protects their Copier/printer firmware, available to only Konica Minolta dealerships and KMBS, need a tech
Feb 15, 2014 | Konica Minolta magicolor 5430 DL Laser...
How up upgrade engine firmware on KM 5430DL?
Have tech come out. mite be able to flash the firmware
Mar 07, 2017 | Konica Minolta magicolor 5430DL
Is there a solution to the C4552 error short of replacing the print head? KM wants $1200
Hi one thing you could try is to update the firmware to the most up to date level also check there is some times special firmware to fix issues similar to this if not you will need to change the print head
Feb 22, 2011 | Konica Minolta Bizhub c203 Copier
Error C-2202
help me clear the system error C2202 on my kyocera KM-C2630D. multifunction copier
Jun 17, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do i load a firmware upgrade on a Konica Minolta 5430DL
it requires some firmware files and another software, which you cannot get easily.so its better to call konica minolta's representative.
May 19, 2010 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta Magicolor 2300W firmware needed
firmware is located on secure web site try having a Konica Minolta tech come out and flash the firmware
Apr 15, 2010 | Minolta magicolor 2300W Laser Printer
Konica Minolta 5430DL error code 111112
I couldn't find the install disks so downloaded the driver from the Konica website, un-installed the software and re-installed it. After calibrating the colours everything seems fine now.
Oct 01, 2008 | Konica Minolta magicolor 5430 DL Laser...
Firmware Problem !
My labels coming Blanco no text label in.
Dec 24, 2007 | SATO M-8450 Printer
Konica Minolta
you can take the mannual from intravia.com
Sep 13, 2007 | Office Equipment & Supplies
Konica Minolta magicolor 5430 DL Laser Printer Logo
832 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
