I have changed the settings per the instructions in the manual, but it hasn't worked. Has anyone gotten this function to work properly?
Is a setting in the printer.
Go to start >Brother> start center> on top go to configuration. then it will ask you for a password. use "access" for the password.
click on general setup and you'll see document scan at the bottom.
Change it from letter to legal and apply.
Voila!
I think he (kabi24) means go to "Control Center" which on my PC is under start/all programs/brother/mfc-9840/control center; then "configuration". But even when you do as instructed above, the system doesn't change from letter size to legal. Try going to start/all programs/brother/mfc-9840/scanner settings/scanner utility, then on the bottom select "Legal" under "maximum scanning size." You then have to restart your PC for this to register. Seriously, the Brother software designers should be shot! This is so ridiculously user-unfriendly and archaic.
Well after some trouble trying to scan my Legal size documented. I found the best way to do it was to open paint and use the scanner or camera option, Here i could choose the are i wanted to scan.
