Question about Jensen TS2750J TV
My jensen tv ts2755j won't power up
I have a jensen ts2755j tv after a lightnig storm it wouldn't not come back on i changed the fues but still won't come on
Apparently there was a bad lightning storm last night that knocked out our power. Bad thing is, when the power came back on our cable box won't turn on and neither will our tv. The tv power button just...
please call a specialist in that for assistance.
As of now and future: Follow what everyone says: "Turn off the modem and TV during a lightning storm".
Jul 25, 2013 | Televison & Video
Unplugged tv for storm, plugged it back in now it trys to turn on but won't
plug in a bed side light and see is it working and if it is not then the storm has damaged the tramsformer supplying your house
Aug 08, 2012 | Samsung Hlr5667w 56-inch Dlp Hd Tv
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
After a lightning strike yesterday the dishwasher won't work - have checked the fuse/plug... what else can I check?
a power surge from a lightnig strike could have caused damage to main control board among other things best bet is have the whole machine checked out!!
Aug 04, 2011 | Dishwashers
Who is liable for s replacement tv if electrical company turns power off and on during a storm and the tv won't come back on?
have you unpluged the power from the tv and the outlet for a few minutes? then plugged it back in?
Jul 25, 2011 | Sanyo Televison & Video
Had electrical storm last night. Tv shows the Westinghouse symbol, nothing else. This is when it is turned off. When you turn it on (from the tv, remote won't work at all), symbol disappears for 30...
If your TV has a reset switch on the back, use it. If not, Unplug the TV, hold the power button down for 30 seconds, let it go and remain unplugged for another 5 minutes or so.
Plug it back in, and see what happens. Try changing the inputs/channels/etc to see what happens. If you're still having this issue, Take your TV in for repair.
- Sidenote, a $25 power bar with built in protection curcuits are the easiest way to protect your equipment from this kind of thing, and quite a bit cheaper than forking over $300 for a new TV everytime there's thinder and lighting.
May 11, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Protect light keeps coming on when i give my jensen amp power
Eith some wires touched, you dont have big enough fues or you have somehting hooked up wrong
May 28, 2009 | Jensen LXA300 Car Audio Amplifier
Jensen TS2750J
my tv did the same thing about one month after i bought it luckily it was still under warranty it turned out that when i had a lightning storm it shorted some fuse inside the part was $100 i tried to replace it myself but it needed a specail tool. good luck
Dec 19, 2008 | Jensen TS2750J TV
No Power
check the fuse first.
Aug 25, 2008 | Jensen TS2750J TV
Televison & Video Logo
123 people viewed this question
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
