LG DLE2514 Electric Dryer
Problem for LG DLE2514 Electric Dryer
LG DLE2514w electric dryer has loud thud every turn
By jerrykropp on Sep 02, 2009
LG DLE2514w electric dryer, drying fine, has continuous thud as drum turns, nothing evident at first glance, where to begin? removed inner fins and cleaned all lint out, drying fine, belt in good order.
Best Solution
posted on Sep 02, 2009
Helpful)
wilson59
Rank: Guru
Rating: 87%, 198 votes
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 09, 2009
Not Rated)
daleec
Rank: Apprentice
Rating: 0%, 0 votes
You may also want to check the drum for a crack along the welded seam. The rear of the drum is supported on 2 bearing mounted rollers. The drum in my dryer cracked in the very back where it is supported by the rollers. Each time the crack goes over the roller it would "thump". It was easiest to find by turning the empty drum by hand and watching the rear of the drum, especially the welded seam. We had the drum replaced but it still makes some noise because the new drum was not as round or consentric as it should be. It does work though. Hope this helps somone.
Was this helpful?
Yes
No
Popular Solutions for LG DLE2514 Electric Dryer
Questions and Unsolved Problems for LG DLE2514 Electric Dryer
Do you recommend LG DLE2514 Electric Dryer?
Answer
Answer
have a model dle2514w lg electric dryer i crossed the wires when i wired the plug in the back of the... (More)
Answer
Not drying. Has good exhaust air, heat is warm, the cooling light is steady lit, the drying light... (More)
Answer
check filter light is flashing and the lights on the dial are all flashing
Answer
I have a LG Tromm front-loading dryer that is very loud. We have made sure the machine is balanced,... (More)
Answer
After the dryer had completed the cycle, it shut off and will not turn back on. When you push the... (More)
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
