Question about Siemens C65
Regulally switched off mobile for 1 hours
My mobile siemens c65 when the call comes it oftenly switched off
  • 81 Answers
Replace the Battery coz if you over charge the battery after that this problem occurs..
Posted on Dec 10, 2007
How can i solved my c65 siemens phone code?
Do you need phone network unlock code for your siemens c65 mobile? Yes means you can visit this site Simpleunlocking.com here you can get the code and unlock your mobile. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email.
Simpleunlocking.com
May 19, 2014 | Siemens C65
Pincode for c65!! it shows code eror!! what to do?
For this problem contact the mobile service provider........
Aug 31, 2011 | Siemens C65
Siemens A70 phone is asking for a subset code.. What can i do??
I guess you wanted to use another network SIM in your Siemens. If it is the problem then you need to get those codes from TheUnlockSpot.com . You need to first order this code. Visit the site and submit your mobile IMEI number which can be got by the following ways
1.While your phone is switched on, type *#06#, your phone would then display its IMEI number.
2.The IMEI number of your phone can be found printed on the phone underneath the battery.
You should also submit your current network and country to place your order. The codes will be sent to you with the instructions when it is available. Follow the instructions and enter the code. Then you will be able to use any network SIM in your Siemens mobile.
Jul 14, 2011 | Siemens C72 Cellular Phone
Siemens charger for hearing aids starts charging and then after some hours one light goes red
Its a warning sign for a faulty battery, the red light comes on if the battery is faulty or if you are trying to recharge a non rechargeable battery.
May 03, 2011 | RTO 1 Siemens Pure 500 Open Fit Hearing...
Whats my PUK code for my siemens c65 phone? its really old but i forgot my pin and i guessed it too much now they require my PUK
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
Jun 07, 2010 | Siemens C65
Fujitsu siemens scaleo 600 desktop just keeps shutting down any ideas
1) Bad Power Supply. Power Supply has a weak voltage power rail.
Electrolytic Capacitors are breaking down inside the Power Supply.
http://en.wikipedia.org/wiki/Switched-mode_power_supply
The capacitors build up a charge long enough to work briefly, then break down.
2) Electrolytic Capacitors on the motherboard are breaking down. Specifically the one's used in the motherboard Voltage Regulator Circuit.
A) http://www.hardwaresecrets.com/article/616
B) Visually identifying bad capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
C) Video showing what happens with bad capacitors (Electrolytic) in the motherboard Voltage Regulator Circuit (Starts at 0:04)
http://www.youtube.com/watch?v=KN6_-8fYHo0
Await your further diagnoses.
May 23, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
How do you move around the phone without the user guide
To view your manual click on the following link. The file is in PDF Format and may take a minute for the page to load.
Download Manual
If you need a PDF reader to view the page, you can dowmload Adobe Reader for free:
http://get.adobe.com/reader/
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 04, 2010 | Siemens C65
Hello!
Hi! my problem is my siemens C65 IMEI 354736001742270 is phone blocked i need your help to unblocked my C65.Please help me to unblocked my C65. Thank you!
Aug 22, 2008 | Siemens SX1 Cellular Phone
My monitor starting problem
Based on your post and brief description, I can only suspect that there is an internal loose connection that eventually contacts better soon as the unit has sufficiently warmed up. It is also possible for a cold solder. More often, these may be found at the inverter board and/or the power board. To determine if it were a loose connection, try to tap on the rear of the LCD monitor soon as you have powered up and you PC has booted. There should be some sign of flickering images or the display would come and go. Should this be not the case, then the other possibility may hold true.
If the problem has been properly identified or whichever it may be, it would require that the unit be opened up for a look and see. Repairs may involve a bit of knowledge/familiarity with electronic components and circuitry, use of a DVM and a soldering iron. Should you not be comfortable doing a do-it-yourself, perhaps your best bet then would be to seek the services of a qualified professional..
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 18, 2008 | Fujitsu Siemens Siemens Basic Line 38B2-M...
Cell Phones Logo
289 people viewed this question
Top Siemens Cell Phones Experts
Stormi  Paulk
Stormi Paulk
Sameer Raut
Sameer Raut
Colin Stickland
Colin Stickland
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
