Question about Panasonic SL-SX287J Personal CD Player
Dropped unit and out popped a spring looking piece.  I cannot tell how it reattaches.  the player still works but the lid won't stay open when changing disks.
    Scholar:
  • 151 Answers
It's just the spring that pushes your lid back up, it's on the far corner of the lid where the lower part attaches to the top part, you need to get it in place there again...
Posted on Dec 09, 2007
The spring mechanism for the lid I guess popped out and I can't get it back in.
What are you talking about ? I do't see what you are referring to. . .
Apr 25, 2017 | Cars & Trucks
I dropped my Panasonic LumixDMC-ZS19 and now when I turn it on, it cycles, but then says Zoom error and won't pop out the lens. Help! I need it!
Hi, it looks like you have damaged the zoom mechanism that's why it will not zoom out . The unit will have to be repaired best to get a quote for repair first.
Jul 16, 2016 | Panasonic Cameras
Dropped it and busted open a piece fell out don't know where it goes & screens not working! What do i do?
it prob one of the control switches you need to get it looked at if you dropped it then you could have damaged the mother board
Jul 06, 2015 | Tablets & eReaders
Why won't the trunk on my 1999 Pontiac Bonneville stay open?
Some have torsion springs running across between the hinges, see if one popped itself out of position.
Mar 24, 2015 | Pontiac Bonneville Cars & Trucks
Sharp r520kst door won't stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Aug 20, 2012 | Sharp Microwave Ovens
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
Dropped unit. Knocked the prisims loose. All
It's quite easy to dismantle and inspect, look for tiny retainer screws around eyepiece and/or unscrew lens shrouds. Normally the prisms shouldn't come loose in average to good quality viewers, they'd be held in by some sort of retainer, eg- flexed, spring tempered metal, where you screw in one side and then have to flex (bend) the metal to screw in other side over the back of the prism. It sounds like yours may use an adhesive retainer, if so clean of old residue and use fresh silicone, or may have broken the clip and or screws. But it may just have popped out, in which case reattach it. Make sure the prisms are seated properly, 1 hardly visible flake of glue or dirt under the prism will offset vision noticeably. I would say you may be lucky and find an honest repairer for about $45.00 if prisms aren't damaged.
Dec 11, 2009 | Swift 779 Birdfeeder (10x40) Monocular
The spring that shuts game cube lid is faulty
Disc Cover open:
Close the Disc Cover.
If the same error continues after the Disc Cover is securely closed, you will need to have your system repaired as it is likely you have an internal malfunction. Please use our convenient repair options
Dec 12, 2008 | Nintendo GameCube Console
Zvue mps player will not turn on
ok... If you have a liiittle experience with a screwdriver, try opening it. you may find cableties that are loose... just try very gently to get them back to thei positions and it will work fine. if this won't do just mail me.
Aug 10, 2007 | Zvue ZV002 Digital Media Player
I dropped and it came apart
Solved it.
If you need to take it all the way apart, here's the scoop:
Get the top cover off by popping it up at the hinge side (this is what pops when you drop it)... then at the charging end, slide the top towards the hinge to slip the clips out from under something.
the folding mic tells the board it is open by a small z-shaped piece of plastic. The skinny end of this fits into a tiny hole in the bottom of the case and the fat side slides up and down in a little round space over on the side of the case. There is a rubber button with a dark piece that sits on top of the round space. The dark side of the rubber piece presses against a round circle on the circuit board and tells it whether the mic is open or closed. Once you put it all together, you have to press the board down pretty firmly to tell if it is all working.
Then put the volume buttons back in place and slide the top back on.
Jan 12, 2007 | Motorola Mobility H700 Wireless Headset
Panasonic SL-SX287J Personal CD Player Logo
101 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
