HP Pavilion a1220n  PC Desktop
Problem for HP Pavilion a1220n (A1220NED904AA) PC Desktop
I need a new mother board
By 4wyatt on Sep 02, 2009
i had lightning strike my house, frying my mother board. how to fix, can i replace whole unit , if i replace what other problems can come up? i am a novice.
Comments:
Sep 02, 2009
- i brought it to a repair tech, he said the power supply was ok but he could not power up mother board. its been over a year but if i recall, it was a dead set... no power at all. i thought he was full of b.s. so am trying figure it out myself.
Clarification Request
Posted by alc03 on Sep 02, 2009
So you did try to start it up and nothing append right ? Did the tech replaced every thing at it place, is it ready to start ? Did he try to change the memory, a memory stick could make your computer not starting at all... Does it make any sound when you try to start it? When you want to find a problem, first of all, you need to know that your computer need absolutly 4 peripheral to start, those are : Motherboard, CPU that is under the fan on the motherboard, Video card and RAM (memory stick) that is/are cliped on the motherboard and surely attach to the power supply. If you ear any sound during the process below let me know! For the instruction below AVOID STATIC So first you need to do is to unplug every thing else and try to start with those four components. If it doesn't start, nothing on the screen, no sound nothing, try to unplug the power supply from the motherboard. You will also see a battery (like a watch) on the MB, remove it. Then gently remove the fan cliped on the MB, try to figure out how its cliped, then remove the CPU under the fan, do it very gently because you could damage materials. Put everything in safe place. Avoid static! After that, try to see if there is a metal piece somewhere around that touch the motherboard. You can also unscrew the motherboard from the chassis if you realy want to make sure, try checking underneat for a loose screw or anything else that could ground your motherboard onto the chassis. If everything is ok, try to put gently everything back together and try to start the computer with only the 4 components mentioned above. Still don't start, if you have more than one memory stick CLIPED ON your MB then try to remove one and start. For the memory, check on the MB to see the bank Nb, its written somewhere around the slot, should be something like : Bank 0, Bank 1 etc. or it could be Dimm 0, Dimm 1 etc. Make sure you have the first bank occupied. Try to exchange the memory. Still don't start, come back...
Are you sure that you fried your motherboard ? What does it do when you power on?
Solution #1
posted on Sep 02, 2009
Not Rated)
prince kambo
Rank: Wiz
Rating: 79%, 18 votes
u have to buy a new motherboard....
Comments:
Sep 03, 2009
- see no need to replace the whole unit ....u just need to replace the motherboard....rest power supply cpu,ram,hard disk will b reused as it as....if those wud b fine........
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion a1220n PC Desktop
Questions and Unsolved Problems for HP Pavilion a1220n PC Desktop
Do you recommend HP Pavilion a1220n (A1220NED904AA) PC Desktop?
Answer
Answer
my computer will only turn on if I put in a CD / DVD
Answer
cant find wireless drivers for ls1000 philips, help me
Answer
I've plugged my webcam in and it's installed but I can't find it anywhere to use it
Answer
install speaker in dell pc mine has no sound Logitech L S 11
Answer
The drive on this PC got corrupted. I formatted it and tried to reinstall windows xp. Got all sorts... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
