Question about Hannspree SD02201100
Hannspree 32" LCD HD READY TV MODEL PRODUCT NO: JT01-32E2-OOOG
I have just purchased the above item and on connecting it to the virgin media cable box I have experienced a banding effect panning the screen also a ghosting effect on peoples faces especially with movement.On disconnecting the cable box and just using analogue programmes the effect is not as pronounced but the reception is not that good.I have had the virgin cable engineer out and he has tested the cable box and has said there is nothing wrong with it.However,not being convinced we disconnected the cable box last night and connected a freeview box and we did not get this banding effect.Has anyone else experienced a fault like this on this tv or on connection with a cable box.Please can you help as I have now informed the tv repair firm who are in the process of supplying me with a replacement TV.Thanking you. (Mrs Hulme)
  • janhulme Dec 07, 2007
    Thanks Bill,
    We did have the cable box previuosly connected to a sharp crt tv and to be honest we could not define any banding on that tv but with it being an older style tv would it have shown up.We do not have any other LCD tv to try it on.What do you suggest,should I get in touch with virgin media again or do I await the other new Hannspree and try again? Sorry for troubling you again.
    Mrs Hulme
Just about every problem I have had has turned out to be relative to the scart sockets. (rolling screen, wrong colour etc).
May I suggest that someone moves the scart to see if it helps.
Rather obvious I know but the obvious often works.
B Hardie
Posted on Jan 08, 2008
  • 934 Answers
Mrs. Hulme,
If you have another Tv in the house try hooking it up to the cable box to see if it experiences the same problem, eliminating the fact that it could be the Tv...
Ghosting and band interferrence that you're describing usually has to do with poor ground. If you're getting good analog signal and if another Tv has no problem hooked to that box it could have been poor ground in the tuner circuit of the Tv - but my first suspect would be that digital box...
Bill
Posted on Dec 07, 2007
  • William Rayburn
    William Rayburn Dec 07, 2007
    As long as you have another Tv on its way I'd just wait. If this replacement Tv has the same problem then I'd contact virgin media and have them bring a new box with them when they come out. It has to be their problem then!
    Have a great day!
    Bill
We were just given a pl26 tv, by can not find where to plug the cable connector into the tv, help
this information may help
32" Protron PLTV-32 720p Widescreen LCD HD-Ready TV - 16:9 ...32" Protron PLTV-32 720p Widescreen LCD HD-Ready TV - 16:9 800:1 6ms ... Front Panel Controls: IR sensor ; LED; Top Panel ... Model: PLTV-32; Product Requirements: HDTV receiver
May 05, 2012 | Protron PLTV-26 26 in. HD-Ready LCD...
Tv connected via scart cables through dvd and virgin media box. Picture sometimes goes yellow the flickers then back to clear.Other times it can go red. Plays dvd's okay though. Is this a connection...
This will be a problem with either the Scart leads (9 times out of 10) or the virgin media box. Not a problem with the signal coming from Virgin Media. Try checking the scart leads are not loose, or looped through the wrong way.
Hope this helps
TV_Doctor
Jan 03, 2011 | Sharp LC-32P50E 32 in. LCD Television
Could you please tell me if my LC-32GA5E tv can work with sky HD.The manual tells about switching to hd mode,but there seems to be no where to connect hd to the set.The tv is about 5 years old. thanks...
This is an HD ready TV and can definitely be used with Sky HD, but ONLY if the Sky box is connected to the TV with an HDMI cable. It will not work if connected with a scart cable.
So you need 2 things. Firstly, you need to buy an HDMI cable (see picture) if you haven't already got one. Secondly you need to locate the HDMI sockets on your TV and Sky box. The sockets will have the HDMI logo (see picture) next to them.
Oct 16, 2010 | Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready...
How do you connect the Virgin VHD box to LG RZ32LZ55 TV for getting HD and also the audio. For the audio the V HD box has a optical audio port and a test port ( i am not sure it works!). The TV has a DVI...
All you need is an hdmi-dvi adapter. You will also need a component audio lead to plug into the mini(3.5) jack socket on the tv as dvi does not carry sound. You will need to initially use the scart to set up your tv for hdmi as the menu can only be seen via the scart until you set it up.
Jul 24, 2010 | LG RZ32LZ55 32 in. HD-Ready LCD Television
No HDMI on the source list, i have a Virgin Media V+ Box with a HD cable pugged in and when i look at the source list the HDMI Port is not Highlighted, why is this? Please help
One of a few things are happening. If you are connected to the TV via the HDMI port and it doesn't become highlighted then either the main board on the TV is at fault, the HDMI output on the media box is not working (try on another TV if possible) or the HDMI cable itself is bad.
Nov 03, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Digital boxes
This model only has an analog tuner, so you will require either a converter box or hi-def tuner after the transition.
Dec 07, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
HD READY
I have the same TV & I've tried connecting it through "component" & the DVI but neither work & a Virgin media tech says only an HD TV will work 'the boxdoesn't recognise component
Steve
May 05, 2008 | LG RZ32LZ50 32 in. LCD Television
Hannspree 37" with Xbox 360 HD
Try to use a HDMI cable, your component cables may not be usable with your TV.
Apr 20, 2008 | Hannspree (K206-10U1-005) Television
Hannspree SD02201100 Logo
318 people viewed this question
Top Hannspree Televison & Video Experts
Computer Links
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
