I have a 93 chevy sonoma and when i start it, it idles around 2-2.5 for about a minute or so and then drops down to around 0 and stuggles to stay running and then seems like catches itself. When i get it moving it will go into reverse fine, but the 1st gear it it idles down and shuts off! but once it warms up its fine. i dont get it! help!
Low pressure from fuel pump, when the pump is cold the pressure increases, as it warms up the pressure drops (this happens in a pump that is going out) the normal pressure should be at 40 with the key on and engine not running, when started the pressure should stay around 36, any less it won't idle and may run as long as you hold the pedal down. The injectors are opened electronicaly, so as long as there is fuel flow the engine gets fuel to run.So check the fuel pump, soundslike you need a new one
No,only on carburated engines it,idles down to the set point,on yours,it's fuel injected,pushing gas pedal won't kick idle down,should go down after a certain amount of time,does it automatically,If you start and drive a 5 mile ride and stop at a stop sign,it should idle at it's set point if there's no engine problems,which may be.5 to .7 on your tac.When you normally first start,it will idle between 1000 to 1200 rpm's,don't push on gas,let idle say 15 seconds,put in drive and go.
idle air control valve is bad replace it. at start up choke control runs till warm up while driving throttle opening controls engine at idle ,the idle air control valve.
I Have a couple of questions. First question does engine surge when idleing cold? 2. Does engine start quickly without a lot of cranking, Cold or warm? 3. Do you have funny smell at highway speed, or after you stop? With out this info and your imput, I would only be guessing. I am retired mechanic of 25 years. and would like to help if u need me.
fuel lines inside the intake plhenum may be cracked and leaking inside the plhenum. same thing happened to my 1992.sonoma. they are made of a plastic material and tend to crack right in the bend of these lines.
