Question about IBM ThinkPad R40 2722 Notebook
IMB T40 All indicator lights are flashing. Black screen and will not power up. Have tried a new battery. Soon as power button is pressed all indicator lights flash.
    Scholar:
  • 132 Answers
Try this: Turn off the computer. 2. Remove the battery pack. 3. Connect the ac adapter.
NEXT:Turn off the computer. 2. Visually check each piece for damage. Replace any thing damaged . 3. Remove or disconnect all of the following devices:
a. Non-ThinkPad devices
b. Devices attached to the port replicator
c. Printer, mouse, and other external devices
d. Battery pack
e. Hard disk drive
f. External diskette drive
g. DIMM
h. CD-ROM and diskette drive in the Ultrabay
i. PC Cards
4. Turn on the computer. It should still be plugged in
5. Determine whether the problem has been solved. 6. If the problem does not recur, reconnect the removed devices one at a time until you find the failing unit. 7. If the problem remains, replace the System board .
Posted on Dec 10, 2007
  • 81 Answers
My FRND,
You have to open the Notepad coz this was the dusting problem in it...
I have an MSI Wind U100 which was powered down without any drama but the next day when it switched on, the screen remained black and only the blue power light plus the Wifi and bluetooth indicators...
It is likely that the backlight went out on the screen. This model has an LED backlight and can be replaced. If you are mechanically inclined, you can purchase a new one on ebay or amazon and replace. If this is a motherboard problem, then it is likely not worth fixing. One way to tell is to see if the screen is completely black. To test, turn on the computer and go near a bright light source. if you can barely make out any image on the screen, then the LED backlight is bad. If the screen is as dark as it is when the computer is off, then it is likely the motherboard.
Apr 17, 2011 | Intel Motherboard
Hello I have an IBM T40 and I have a problem. when I connect the power cord , the battery LED lights that stay lit orange. I press POWER button and will not start. only hear a noise and flashing orange...
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 25, 2011 | IBM ThinkPad T40 2373 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
My IBM T40 boots to a black screen with the "z"(light at top to right of power.
Try these steps:
1. Remove battery and unplug AC adapter
2. Press power on button for 30 seconds or so (one min is also too)
3. Attach battery and plug into wall
4. Power "ON" as normal
If you are still getting the "Z" and a black screen then I would have the video card or hard drive looked at and replaced. Start with the video card and then look at the hard drive
thinkpad-t42-wont-boot.html">http://www.techsupportforum.com/hardware-support/laptop-support/234433-ibm-thinkpad-t42-wont-boot.html
Feb 17, 2010 | IBM ThinkPad T40 2373 Notebook
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
"z" light comes on, then battery charge indicator -Doesn't start!
If there no indicator of power on the laptop , There could be two problems either the AC adapater is bad or the motherboard connector pin or board is faulty.
If you see power light activity , but the screen is blank. try connecting an external monitor to the laptop. Press the Fn+ F8 key to toggle the screen to the external display. If you see the display on the external screen then the LCD is bad . Otherwise its your video card.
Thanks for using fixya
proton
Aug 14, 2009 | IBM ThinkPad T40 2373 Notebook
How to use the S view port - switch monitor
Press the blue FN button and one of the F1-F12 buttons. It should show two screens. Also make sure you have changed the display settings in windows. Under the advanced Tab check the box that says "extend my desktop to this screen" after selecting the 2nd screen in the window above it.
Aug 19, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad R40 2722 Notebook Logo
268 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
