Question about Audiovox D1708 Portable DVD Player
Battery charging
When I try to charging my battery the charging light come on steady for appox. 5 to 20 second then it start blinking and wont charge.
    Sergeant:
    Champion:
  • 362 Answers
Its possible your power converter is bad have the output voltage checked.
Posted on Dec 08, 2007
Charger light blinks rapidly for dewalt charger?
usually indicates battery has failed slow blink charging steady red fully charged
Nov 03, 2017 | Dewalt Drills
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Put new alternator and battery in 1995 Buick Lesabre with key pass will turn over and run afew seconds but wont stay running
actually a pretty easy fix. The pass key computer lost its programming. Put the key in and leave it on with the security light flashing. Just turn off all your accessories and make sure battery is pretty good charge. Anyway after you leave the key on for ten minutes the security light will come on steady so turn key off and right back on and start car. If security light still starts blinking and car stalls then do it again. It will usually work the first time but can take a few times to get it right.
Dec 27, 2010 | Buick LeSabre Cars & Trucks
Toshiba satellite A100 dead. orange steady battery light with mains connected and power button lights shift key and 2 function lights - that's it.
It will turn GREEN when the battery is fully-charged.
Is there a problem with the battery not accepting a charge?
Remove the battery, to see if the computer will start without it.
Do these 2 lights just "blink" once, and then go out?
Does a "power" button stay lit?
Have you hired a professional computer technician to trouble-shoot?
Sep 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
Indicating steady red light can not charge
Rub the terminals of the battery with your fingers and than again put it on charging .... before doing that remove the battery from the cell for an hour..
May 21, 2009 | i-mate Ultimate 9502 Cell Phone
2001 Explorer; anti theft light steady; no power to car
take the positive side of the battery off for about 3 seconds and then put it back on to see if this will reset the security code
Apr 26, 2009 | 1994 Ford Explorer Limited
Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Nov 03, 2008 | Olympus Stylus 710 Digital Camera
Ready lamp on 283
When the flash goes into battery saver mode, which it does automatically, the light will blink.
If you are using the external power source, the light should remain steady.
Jeff
Oct 30, 2008 | Vivitar 283 Flash
Westinghouse Unplugged Vacuum Turns off after 5 Seconds.
If both batteries are behaving the same way then this is probably a charger problem. When you insert the battery pack into the charger does the 'charging' light blink for 30 minutes (fast charge) then go steady? I noticed that one of my batteries was causing the light to come on steady immediately I inserted it into the charger. When I tried to use the battery pack I got the same problem everyone else is seeing, i.e. vacuum cleaner shuts off in less than a minute, so I conclude that when the charging light is on steady then the battery is not being charged.
If the charging light does not blink when you insert the battery (i.e. comes on steady or not at all), try removing the battery and re-inserting it into the charger.
Try a conditioning cycle on your battery packs. To do this:
* Insert the battery pack into the charger
* Before the charging light lights press the 'condition' button located just above the charging light.
* The 'conditioning' light should blink. This is a light which does not normally illuminate, and it is located below the condition button and above the charging light. The charger fan will run quieter in this mode.
* Leave the battery pack in the charger for 24 hours while this cycle is taking place.
I'm not a service technician so perhaps someone else might like to post other solutions or corrections to this one.
Mar 07, 2008 | Vacuums
Audiovox D1708 Portable DVD Player Logo
331 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
