Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Dishwasher not starting cycle
By aslav25 on Dec 07, 2007
Hi guys my dishwasher wont seem to start the cycle, it has power, i choose the cycle and press start but it wont go any further can you help us out please!
Same Problem
Sep 30, 2008
-   I have same problem! Does anyone have a fix for this? -   apharcha
Sep 30, 2008
-   Same problem but no fix. Does anyone have a fix for this issue? -   apharcha
Jan 22, 2008
-   Belling IDW 603. Can switch power on and off at main switch on LHS of door. Can select all programs 1-9 and select timer, options etc. When working you select a program and press start. The machine will display the cycle time. When the door is closed the machine beeps and starts cycle. Now when I select program and press start nothing happens. No display of cycle time or anything. I tried a random selections of buttons and got it to run. It worked for 5 or 6 more cycles but now nothing. I have checked the filter on the water inlet but it was clear. I have left unplugged for 5 minutes and retried with no success.-   Denny 2
Best Solution
posted on Dec 09, 2007
Helpful)
Bob from LI
Rank: Guru
Rating: 85%, 740 votes
aslav...Does it do anything at all and how do you know it has power? Find and turn the breaker fully off and then on to reset it.
You don't say how old the unit is. If it has a mechanical timer, is it one you can turn? If so, turn it. If it starts to do something...this gives you an idea what's happening. Try a different cycle.
The first things a timer 'authorizes' in a dishwasher are: water in and start of pump motor. If neither is happening and power is on to the connection under the unit (use a voltage tester you get from the hardware store), then replace the timer. My bet: no power.
Was this helpful?
Yes
No
Solution #2
posted on Dec 08, 2007
Not Rated)
james klgr
Rank: Guru
Rating: 87%, 241 votes
a dishwasher has a timer similar to a dryer you need a schematic so you can check the voltages at the heat cycle some times the timer goes out, and rarely the heating element or pump goes out. and make sure when you press start power travels through the button.
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
Siemens SL34A006UC Dishwasher not cleaning top rack
Answer
We have a Kenmore ultrawash dishwasher. After about 3 uses the dishwasher cuts out. A new fuse was... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in New York, NY
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
