Question about GE Spacemaker JVM1640SJ Microwave Oven
My microwave sounds funny
My microwave started sounding strange tonight, much louder than normal and apparently it isn't cooking correctly. It is only 2.5 years old so it doesn't seem like it's time for it to die. Do you have any advice?
Thanks,
Clare
  • 5,911 Answers
If the sound you are talking about is a loud humming noise, this is usually caused by a component in the High Voltage Circuit going bad (Usually the Magnetron and/or HV Transformer). Depending on make and model, some of these components can cost as much as a new microwave oven. The unusual noise, associated with improper cooking results, leads me to believe you could have a bad magnetron. The transformer tends to be a bit more resilient. This is not a job that I would recommend for someone that has no electronics background, however. The HV circuit has voltage potentials of 14,000 volts or higher, and it is not recommended to take any live readings in this area due to the danger associated with the high current. I'm not trying to discourage you at all. If you have the technical "know-how" and can disassemble the unit enough to take resistance readings (no power applied) on the magnetron and/or get a part number (sometimes located a parts manual that comes with the owner's manual), it may be worth the effort to see how much a replacement part may cost. If you go to repairclinic.com, type in your make and model number, you can get a pictorial parts index with prices. Let me know if this helps you.
Posted on Dec 07, 2007
  • GE Master
  • 9,098 Answers
This answer assumes yours is a GE JVM1640, as posted.
If not, please reply back with your correct brand and model.
Most of the time, this is the magnetron, which would have a 9-year warranty.
I would advise you to contact GE Customer Service at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Microwave not cooking food at all,motor sounds louder
This indicates the magnetron has failed, the most expensive part in the microwave oven.
Jul 11, 2012 | GE Microwave Ovens
When you start the microwave it starts normally with a low hum, then a couple of seconds into it the hum gets louder. After the cook time has expired the food is still frozen. Is there something I can do...
Replace the magnetron by the sounds of it. The hum gets louder a second or so into "Cooking", that would comply with the magnetron heaters coming on and working into a dead magnetron. It could be capacitor or diode of course.
Dec 27, 2010 | GE JVM1540SMSS Microwave Oven
Microwave turns on but it makes strange noises and does not cook anything. After a little while I get an error message that says something like cooking sensor has timed out
So we can help you, please post a NEW question, and please include your full model number from the tag in or on the unit, as well as the answers to these questions:
When you try to microwave are the inside light, internal cooling fan and turntable all working?
Is there any unusual noise or is it louder or quieter than normal?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Oct 11, 2009 | GE Microwave Ovens
Microwave makes strange sound when turned on
The fan motor either needs maintenance including lub or it need to be replaced.
Jan 01, 2009 | Kenmore Microwave Ovens
Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Dec 07, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Strange sound - seems to cook too hot?
It sounds like either your inverter is producing too high a voltage, or your magnetron may be damaged, causing it to overcook. In either case, it definitely needs professional attention. There are very high voltages involved. Since it's out of warranty, the repair charges would likely run about $75-90 labor for in-home service (less if you carry it in) and about $40-75 for parts depending on which is bad. If you run into a technician who can repair the inverter instead of just swapping it, you might save a bit.
Sep 13, 2006 | Panasonic NN-S252WF Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
262 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
