The far left terminal is the only one that was damaged and its not that bad. Can I use this terminal block again instead of buying a new one. I've fixed all the loose wires and put new connectors on just about every wire that I could get to.
get a new one they're not that expensive, you should be able to pick up a universal term block at an electrical supply warehouse or distributor or a hardware store dont keep a fire hazard around for that small amt of money
I just received an old portable washer/dryer--an Avanti 2001S. To use this machine, instructions...
(More)
I just received an old portable washer/dryer--an Avanti 2001S. To use this machine, instructions found on the inside lid say,(1 )it has to be connected to an individual branch circuit;(2)minimum size wire 14awg;(3) and fuse circuit breaker max 15 amp.Please explain what these terms mean. I live in a small apartment, electric heat and water...no gas.
i have emptied the water tank cleaned the fluff filter and the condenser but the water tank light...
(More)
i have emptied the water tank cleaned the fluff filter and the condenser but the water tank light will not go out and the dryer will not work.
1998 Honda Civic EX; heater blower motor was making loud noises. Pulled motor and bought new one...
(More)
1998 Honda Civic EX; heater blower motor was making loud noises. Pulled motor and bought new one but do not know how to remove the white plastic fan off the old moter.
