Question about Frigidaire FMV156D Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
Hi... My microwave worked fine, and then one day no heating, no turning, no sound. Everything else works. I've tried reprograming the settings, unplugging and replugging. Still nothing....What is it?
  • 11 more comments
  • Anonymous Jan 01, 2008
    Have Kenmore Microwave Model No.721.80012401.
    Everything is working except it is not heating or warming up.
  • Valerie13 Jan 15, 2008
    The microwave will not heat. You can set the time and it looks like it is cooking- the light comes on the turntable spins, but no heat.
  • rigit Feb 10, 2008
    I have the same problem with the same microwave. The light turns on, and the timer counts down, but the turntable does not spin and there is no cooking, also there is no beeping sound when you press the buttons or when the timer times out. Is there a fuse inside that needs replacement, or what?
  • martinjk Apr 19, 2008
    when i set the timer it acts like it is turning on...the light comes on and the counter starts counting down, but it does not start heating or do the humming like a microwave that is cooking. everything still works...the vent, the light, the timer
  • Anonymous May 29, 2008
    We have the same problem the light and the timer comes on but no heat and turn table does not rotate. I understand this could be a door switch problem.....does nayone know how to fix it.
  • laurietw Jul 09, 2008
    My microwave does the same looks like it's working, but when you take the food out it's still cold. There was a loud POP noise, and then it stopped heating. I would like to fix this myself because a service call alone is $75.00. Any solutions?
  • coldilnino Sep 03, 2008
    Same problem. Yes, we can set the timer and the count down begins. The light inside comes on as well. However, the turn table does not turn nor does the microwave heat anything. No humming, no action, no heating.
    I can turn the fan on. I don't know if that is relevant.
    If I let it sit for a bit, it will actually heat for a while, then stop heating.
    I took the bottom panel off but I cannot seem to get the microwave away from the wall to get the plate under the panel off and dig deeper. The metal plate under the bottom panel is quite hot, though.
    It had been used recently so I do not know if it is cooled down from that yet or if it is part of the problem.
  • mogonzalez99 Oct 12, 2008
    I have the same problem, the way i get it to start rotating and heating is applying a bit of pressure (upwards) on the door and i guess it hits a switch which makes the oven turn on. I think the door needs adjusting becuase the door clamp hits a red switch inside the oven when i slightly put pressure upwards on the door. I just don't know how to adjust the door or raise it up a notch on the handle side to let the clamp hit the switch that make it turn on. What i'm doing in the meantime is setting the time, hitting the start button, raising the door at the right angle until oven starts heating, holding it in that position until the time elapse. Its a temporary solution but frustrating and not to mention getting very old!! Do i need to call a repair center or can i fix it myself??
  • Anonymous Dec 05, 2008
    In the middle of cooking tonight the cooking just stopped. The timer works, but still no cooking when you hit start. If I push the door handle up it starts spinning and sounds like its cooking/running, but isn't heating anything. Is it just the door switch?
  • Anonymous Dec 28, 2008
    Same problem. It sounds and looks like it's working, but no heat.
  • Anonymous Mar 13, 2014
    The turntable on the microwave does not spin nor does the microwave
  • Anonymous Mar 19, 2014
    turntable doesn't turn, but everything else works fine
  • Anonymous Mar 22, 2014
  • Frigidaire Master
  • 9,098 Answers
This is just a preliminary reply. We will need more information to help you.
So you're saying you can set the cooking time but when you press Start it won't start?
If this is the case, you probably have a bad door swithc or door switch mount.
Please reply back with more detail so we can help you.
Posted on Dec 07, 2007
Your 'Preliminary Reply' doesn't make too much sense because all of the problems have been stated clearly. Has anyone found a solution? How about directing me to another site? Thanks in advance.
Posted on Oct 08, 2008
The microwave isn't heating/cooking on any setting but the turntable, light is working. What should I check before calling a repairman?
There is nothing more you can do, you have verified everything is working except it is not heating the food. The next step is have the repairman come in to isolate the cause.
Jun 02, 2011 | Maytag MMV4205 Microwave Oven
LMA1560SB microwave--everything works fine (lights, clock, turntable) except does not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Apr 16, 2011 | LG 1.5 Cu. Ft. Full-Size Microwave - Black
Everything works ok except the turntable. It does not turn. Food still cooks, and is very hot as it should be.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Mar 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave lights up, turntable turns, timer works, everything works but it does not heat or cook anything??
Sep 16, 2010 | Whirlpool MT4110SKB / MT4110SKQ 1100 Watts...
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Microwave is not cooking/heating.
sounds like the magnatron they can just go out like a light bulb easier to buy a new microwave hope this helps regards Jim
Apr 13, 2009 | Microwave Ovens
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
Apr 15, 2008 | GE JVM1650 1000 Watts Microwave Oven
Frigidaire FMV156D Microwave Oven Logo
620 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
