Question about Samsung DLP HL-P5663W 56" TV
HL-5686W Shuts intermitantly shuts itself off.
Is this a symptom of a problem that will get worse. Could it be a timer that is set to turn off the lamp, in order to extend it's life? Does it sound as though the lamp is going out? I am relatively techy. How difficult is it to replace the lamp myself?
  • prollin Dec 07, 2007
    Thanks for the help. This DLP set is only about 6 months old. I bought it from Best Buy. I also purchased an extended service policy. So, I will call them to come take a look at it. Unfortunately, it probably won't go out while the are here. It will wait to go out until I have a house full of family and friends during the holidays. That would be fun. Sister-in law is watching, and it goes out. I might pay to keep it broken.
  • Anonymous Dec 11, 2008
    I have the same problem. I dont see any color or or focus problems. Picture looks fine it just shuts off more regularly now as time has gone by. Luckily I bought an extended waranty
  • 934 Answers
No such thing as a timer on the lamp system, but it does have a thermal fuse.. But it would only take one overheating and the set would not come back to life on its own..
The one marked problem this particular unit has, that I've seen about a half dozen times or so, is faulty color wheels. Even though there is no video or color distortion the motor in the color wheel can begin to drag cause an excessive load in that assembly and eventually to the symptom you're describing. But it could equally be something else in the system loading down the power supply and causing the shutdown.. It's difficult to say without some testing.
You say you're "techy"... Do you own a scope, logic probe and an ESR meter? If not, better leave this one to the techs. If you do I have the service manual and could Pando it over if you'ld like to trace test the SMPS and wheel.
FYI: there is a new wheel assembly for that unit that replaces the type that unit was assembled with at the factory - under Samsung p/n# Bp96-00674a.
Hope this helps!
Bill
Posted on Dec 07, 2007
Orbit timer lets sprinkler run for 20 seconds and shuts off
replace timer, they do go bad, they are not expensive home depot or Lowes
Jul 30, 2018 | Orbit Hardware & Accessories
Canno turn the tv on.
You probably have a main or high voltage power supply problem; the latter produces the 20,000 plus volts for the CRT and gets its voltage from the main supply. It's difficult to say which is at fault without a few measurements.
Feb 14, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Samsung dlp model# hl-s 5686w. Set comes on and plays for 5 to 7 seconds. The picture starts dimming with sound then eventually shuts off. I can turn it on again and the problem repeats.
replace lamp at is easy and if you have instruction book that came with tv shows you how
if nit the lamp ib behind cover on side or behinde long frount cover that comes off by undoing two screws ( big black ) on back corners of tv and a sharp pull once removed there is another screw ( black one ) undo and you will see lamp now with alen key undo the two screws and pull out lamp refit is revrse
Dec 13, 2009 | Samsung DLP HL-P5663W 56" TV
Keeps shutting itself off
hi, just check whether you have set any timer. It may possible that you have set some timer, thats why it keeps shutting off!!
Or may be due to power fluctuation but it happens rarely
Sep 19, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P5663W
your tv need to be re solder ,it's the first step your going to do.if nothings happened check the supply vertical IC or the IC itself.
Oct 31, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba 40H80 - Turns on . . . wigs out for about 30-seconds . . . shuts off.
A convergence problem is very commond. In most cases the convergence output amplifer IC's need to be replaced. This is not something you should do. Call a repair shop.
Apr 15, 2008 | Toshiba 40H80 40" Rear Projection...
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Problem with tv turning off by itself.
First of all, you should try making sure in your menu that you do NOT have your timer set to shut off.  You'd be surprised how many people call Zenith every single day and fuss at me because their tv is 'broken' and they have a timer set.  Secondly, it sounds to me like it could be an issue with your power supply.  Does it turn itself back on randomly as well?  Do you hear any popping sounds when it turns off?  Check with your manufacturer to see what their repair warranty is.  Some have full warranties for 90 days parts and labor, and some have it parts and labor warranties for a full year.  You'd be surprised how much the customer service agents working for your tv's manufacturer actually know about the product.  Give them a call for sure to get more information! :)
Oct 21, 2007 | Samsung DLP HL-P5663W 56" TV
TV Picture Freezes and Turns Off; Cannot Use Remote
My shop had this problem yesterday. We had to change the DMD to correct it. One of the data lines was being drawn down intermitently. This doesn't eliminate the digital PCB, but, we have seen the DMD do this more than a digital. You should have an authorized shop do the repair. Contact Samsung at 1-800-SAMSUNG or contact by email: http://samsung.com/ContactUs/ContactUs.htm Hope this helps.
Mar 30, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
327 people viewed this question
Jerry Greenberg
Jerry Greenberg
