Question about Brother HL-2070N Laser Printer
Paper jam light won't turn off!
The paper jam light won't stop flashing on my Brother HL-2070N laser printer. I've tried everything...more paper, less paper, running cardstock through the paper path with the printer turned off, cleaning the feed wheels, opening and closing all of the doors, turning it off and on, unplugging it, changing the settings (Tray settings > Manual > paper size changed from "undefined" to "letter"), holding down the big blue "Go" button. There is no paper jam, and nothing will stop the light from flashing. All of these things seem to have worked for someone or other out there, but none of them are working for me.
I hate to throw out what otherwise seems like a perfectly good printer, but it won't work unless I get this light to stop flashing. I can't afford to take it to a repair shop, so any other suggestions would be much appreciated.
Thanks so much for your time!
  • Epiphany Dec 07, 2007
    PS - I also tried removing the toner cartridge and looking for jammed paper behind there, and removing the paper tray altogether.
  • JTomanelli Jan 30, 2008
    Ditto - The paper jam light keeps flashing and will not print.
    Open front, back, removed tray, made sure there were not pieces of paper in the grail but actually got it to stop. It printed about 5 documents and started again.
  • Brother Master
  • 1,113 Answers
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
Paper is jammed half way out on HL 2070N model
open the rear access door and pull the paper backwards through it then firmly and smoothly pull the paper free ofrom the fuser. pull the paper straight. should be easy.
Apr 08, 2009 | Brother HL-2070N Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother HL-2070N red "paper" light flashes after a paper jam
http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
2070N brother printer has flashing paper light
There is a paper jam inside your printer . Clear those paper , your problem will be solve.
Jan 10, 2009 | Brother HL-2040 Laser Printer
Brother hl-2070n; Paper jams half way through drum unit.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Nov 19, 2008 | Brother HL-2070N Laser Printer
HL-2070N paper LEd flashing
most likely a sensor is tripped, eiher it's stuck or there is something blocking it. the most likely place is in the fuser, back door where paper exits and geta hot. look closely you should see a black lever towards the middle of the fuser, it should be up
Oct 18, 2008 | Brother HL-2070N Laser Printer
Flashing paper light
there is a sensor maybe is stuck
Apr 06, 2008 | Brother HL-2070N Laser Printer
Printer prints crooked (8.5 x 11 from paper tray)
check that the paper guides on paper cassette are hard up against paper edges
Oct 27, 2007 | Brother HL-2070N Laser Printer
Brother HL-2070N Laser Printer Logo
476 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
