Your drain line is most likely pluged with gunk. You need to blow out the drain line. The drain line should be located in the upper section of the fridge where the air blows in. There will be a little drain cap that comes off with the drain line behind it. Get an air hose with high pressure and blow into the drain line to clear it out.
The reason to this problem can be due to the
clogging in the drain line.
