Question about Tomtom ONE GPS Receiver
Internal server error
When i try to update my tomtom one i get an error internal server error.
    Scholar:
  • 143 Answers
Try updating to the latest tomtom home software.
http://www.tomtom.com/support/support.php?ID=2
Posted on Dec 16, 2007
Microsoft Exchange Server. HTTP 500 Internal Server Error.Any recommendations?
To resolve this problem, follow these steps on your Exchange 2000 or Exchange 2003 back-end server. Alternatively, follow these steps on another computer that has access to the same domain controller and the same global catalog server.
NoteThis procedure requires the Exchange Server Fix Toolbox
1.Start the the Exchange Server Fix Toolbox
  1. Right-clickYour_back-end_Exchange_server, and then clickProperties.
  2. Clicknetworkaddressin theAttributeslist, and then clickEdit.
  3. Add a new value forncacn_ip_tcp. Use the FQDN of the server instead of the NetBIOS name or the host name of the server.
    The syntax for this value isncacn_ip_tcp:FQDN. For example, if your Exchange back-end server has a host name of EXCHANGE1 and the FQDN is EXCHANGE1.domain.com, use the following value forncacn_ip_tcp:ncacn_ip_tcp:EXCHANGE1.domain.com
  4. Remove the oldncacn_ip_tcpvalue that contains the NetBIOS name or the host name of the back-end server.
  5. Apply this change.
  6. Because your Exchange computer may change this value back during a failover or a system attendant restart, configure the following registry value on both nodes of the cluster:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\MSExchangeSA\Parameters\UpdateProtocols
  1. Right-clickUpdateProtocols, clickModify, type0in theValue databox, and then clickOK.
  2. If your network uses a Hosts file on the back-end cluster node, modify it by using the following order of entry:
  3. Restart the Exchange services on the back-end cluster node.
  4. If there are multiple domain controllers, wait for replication to occur before you try to log on from the front-end server. If the problem is not resolved after replication is complete, restart the IIS Admin Service on the front-end server.
You can obtain the Exchange Server Fix Toolbox by visiting the following site: https://www.fixtoolbox.com/exchangeserverfix.html
Jul 27, 2015 | Microsoft Exchange Server for PC
When turn On can get the screen showing the GPS connected to Computer when not connected ,On Battery only, get red cross flashing
If your TomTom shows a red cross, it means the device is not able to load the software to be able to operate. Some devices have this software on a SD-card, some have it stored on an internal memory.
If there was a SD-card in your TomTom, I would suggest to put it back. If there is a empty SD-slot on your device, it could be you lost your SD-card, but some TomTom devices have an internal memory AND a SD-slot for memory extension, so if you have an empty cardslot it doesn't necessarily mean there has to be a card in it.
When you never saw a SD-card, probably some data went corrupt on the internal memory. When you have a SD-card, probably some data got corrupted on the SD-card.
To repair the software, you need to connect your GPS to your PC or Mac with a USB cable.
You also need the program TomTom HOME. You can download it for free on the TomTom website.
With TomTom HOME you can update the operating system of your device for free (map updates are nor free).
Try updating, and see if your device works again.
If this doesn't work, post it here.
May 14, 2015 | Tomtom GPS
When i bowse the web it often says internal server error and wont display the screen, why?
An "Internal Server Error" is an error on the web server that you're trying to access. That server is misconfigured in some way that is preventing it from responding properly to what you're asking for.
Unless you own the website you're trying to access and can reconfigure the servers, it's not your problem and there's nothing you can do about it (for better or worse).
Mar 29, 2011 | Cell Phones
Trying to do a map update. but my computer will not recognise the gps, do i need to download a driver for go 720 ??
I had this issue with my Go930 and solved it for Tomtom!! Firstly, you need to ensure that you have the most up to date version of Tomtom Home, from here (http://www.tomtom.com/services) and then before you dock your 720, put an SD card in. It doesnt have to have anything on it and you should only only have to do this the first time. Tomtom home will then ask you which device you wish to update, internal HDD or external. Choose the internal HDD and you are sorted
Feb 19, 2010 | Tomtom GO 720 GPS Receiver
It says "no maps found"
I had the same problem before on a TomTom GO 730. The free internal memory was too small to hold the updated map so installation failed (the download to PC was OK, the message is misleading).
It's a TomTom software bug to not check on the available free memory properly before the update process is started.
My TomTom device required a new software install from scratch. Remove any excess MP3 or unused voices before you retry the update.
Feb 06, 2010 | Tomtom One XL GPS Receiver
I cannot download maps into my tomtom avn2210p from tomtom home , internal server error code 500
I would suggest you to look into Underground GPS forum. It has some good info. TomTom official site is not the only way to get and update maps on AVN2210P. Currently I am using version 840 latest USA and Canada map with Navcore 7.833 with no issue. Good luck.
Oct 09, 2009 | Tomtom GPS
The server encountered an internal error
just refresh...if that doesnt work Re-type the youtube address if that doesnt work try a different brower...if u dont have another browser download some
konquerer, opera, firefox, flock, chrome
May 16, 2009 | YouTube Videos
ERROR: 573/#https://home.tomtom.com/shop/onetimeDeviceUpdates: Error from server: You have an invalid version of the TomTom application installed on your TomTom device. To use HOME you need to install the...
Go to My Computer, then the TomTom drive and click explore. Move your Map folder to the desktop. Then, delete everything on the tomtom drive. Unplug it, plug it back in, and start up Tomtom HOME and install all updates, keep unplugging, plugging back in, and installing updates until there aren't any more updates. Then move your map folder back to where it was on your TomTom drive.
Please rate, Thank you!
Dec 27, 2008 | Tomtom ONE 3rd Edition GPS
Downloading Free Maps for TomTom GO 720
I want dowloading free maps for tom tom go 720
Apr 02, 2008 | Tomtom GO 720 GPS Receiver
Tomtom One 3rd Edition will not update US/Canada Map
sounds like you don't have enough space to download.
Nov 25, 2007 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
649 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
