Question about Magic Chef CAV2005A Top Load Washer
Magic Chef CAV2005AWW makes a noise in agitate cycle
When in agitate, the machine makes a terrible noise, like a bearing going out. Sounds normal in spin cycle. Where do I look next?
  • Anonymous Mar 27, 2014
    When on the spin cycle the machine makes a terrible noise - as though some bearings have gone.
  • 51 Answers
Sounds like a problem in the gear case. This would be a transmision replacement.
Posted on Dec 07, 2007
Washer vibrates badly in spin cycle.
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Feb 28, 2013 | Magic Chef CAV2000AWW Top Load Washer
Maytag Performa Washer niosy during wash-cycle. Spins OK and without any noise.
Check this link :
Jul 02, 2012 | Maytag Washing Machines
My top load when it spins it makes a loud noise sounds like a huge fan spinning or tires squaling
The bearings are bad. Perhaps had water leak into them. Maybe just age. Replace main bearing or... Call repair guy or... look at replacing machine
Nov 10, 2010 | Magic Chef Washing Machines
Margic Chef washing machine makes loud ginding noise when agitating and on the spinning cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Magic Chef CAV4000AWW Top Load Washer
Tub does not spin but agitates
Sounds like the door switch is either loose or faulty. The door switch keeps the tub from spinning with door/lid open.
Charlie
Aug 21, 2009 | Washing Machines
Magic Chef 20lbs hd won't agitate
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.......
Jul 23, 2009 | Magic Chef CAV2000 Top Load Washer
Magic Chef Clothes washer model CAV2004AWW
Something locked up on the transmission then the drive belt broke. Put on a new belt and try a spin cycle, if it works but it won't agitate then the trans will need replaced.
Feb 28, 2009 | Magic Chef CAV2004A Top Load Washer
Agitator is making noise
bearings in the transmission are going out. they are fairly cheap if you can change them yourself.
Mar 29, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Magic Chef CAV2005A Top Load Washer Logo
535 people viewed this question
Top Magic Chef Washing Machines Experts
shaun taylor
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
