Question about Lexmark X83 All-In-One InkJet Printer
Printer keeps reprinting same material
I try stopping the printing by closing the window or trying to cancel it, but it just says, "trouble communicating with the printer" , and keeps on printing. I have tried unplugging the power cord and the USB, that did not help.
    Novelist:
  • 148 Answers
Hi Canela,
Unfortunately most printers have what is called a Cache memory. once you initiate a print job the computer loads it in to the printer, Much like filling a glass of water then the printer takes slow sips so as not to overload the job..if you decide to cancel the print job at your computer you also have to hit the stop button on the printer. In most cases this will empty that "glass" Out and clear the memory. In Vista this problem is inherent to that O.S. I'm still an Xp kinda guy. I hope this helps. Be mucho blessed.. Mark
Posted on Jun 27, 2008
How do I clear the spooler queue on my printer?
  1. Open Devices and Printers by clicking the Start button , and then, on the Start menu, clicking Devices and Printers.
  2. Click your printer's icon, and then click See what's printing on the command bar.
  3. Right-click the document you want to reprint, and then click Restart.
Mar 25, 2016 | HP Office Equipment & Supplies
49.ff05 service error hp laserjet p5200
there is nothing wrong with your printer!! it is a connunication issue from the computer to the printer... cancel the document that you tried printing and try reprinting it again.. to clear the error remove the USB cable or Network cable then turn off the printer.. then back ON while the printer is in the ready state re attache the USB or Network cable and reprint the document :-)
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Jan 02, 2014 | HP LaserJet P3005d Printer
Need to print a fax in memory, machine was turned off and unplugged
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory
option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Card keeps jamming and ribbon breaks
Download the Fargo Diagnose Utility .
But Requires Windows 98, 2000, NT, XP, Me; 16MB of RAM (Recommended); SVGA Monitor (800x600 or higher is required); and at least one printer drivers installed.
If a card becomes jammed inside the printer, the LCD Display will indicate
approximately where it is jammed. At this point you can either try to correct the
problem and continue printing with the same card, or remove the card completely
and continue printing with a new card. Refer to the following steps for instructions
on doing either:
1. Leave the power ON, and open of the printer?s Top Covers.
2. Remove the ribbon and overlaminate as needed.
3. If you would like to try to correct the problem and continue printing with
the same card, do so by pressing the On/Cancel button to advance the card or
the Pause/Resume button to reverse the card. Use these buttons to help free the
card from its jam. Try not to move the card too far from where it was just
before the jam occurred. Once the jam is cleared, replace media, close the Top
Cover(s), and press the Pause/Resume button to resume printing.
4. If you would like to remove the jammed card completely, do so by using the
On/Cancel and Pause/Resume buttons to manually eject the card. Then,
replace media, close the Top Covers, and press the On/Cancel button. At this
point, the LCD Display will prompt you to either press the Pause/Resume
button or the On/Cancel button. Pressing the Pause/Resume button will cause
the printer to feed in a new card and reprint the job which originally jammed
along with all subsequent jobs still being sent. Pressing the On/Cancel button
will reboot the printer and cancel all jobs within the printer?s memory. In this
case, you must also cancel and resend the print jobs from your computer.
CLEARING A RIBBON OR OVERLAMINATE JAM
If the ribbon or overlaminate becomes stuck to a card or jammed inside the printer,
the LCD Display will indicate that it is jammed. Refer to the following steps to clear
the jam:
1. Leave the power ON, and open the printer?s Top Covers as necessary.
2. Remove the Take-Up core (the side with used ribbon or overlaminate on it)
from in between the two black Drive Hubs.
3. Steadily pull the ribbon or overlaminate free from where it is jammed. If stuck
to a card, pull the ribbon or overlaminate off the card and throw the card away.
If it is jammed underneath the rollers, press and hold down the printer?s
Pause/Resume button as you gently pull up on the ribbon or overlaminate. Do
not **** the ribbon or overlaminate to free it, since this will increase the chance
of breaking it. If it does happen to break, simply tape the broken end of the
supply roll directly onto the take-up roll. Then, wind a few inches worth of
ribbon or overlaminate from the supply roll onto the take-up roll. Be sure the
ribbon or overlaminate is passing beneath both the supply and take-up rolls.
4. Once the jam is cleared, replace media, close the Top Covers, and press the
On/Cancel button. At this point, the LCD Display will prompt you to either
press the Pause/Resume button or the On/Cancel button. Pressing the
Pause/Resume button will cause the printer to feed in a new card and reprint
the job which originally jammed along with all subsequent jobs still being sent.
Pressing the On/Cancel button will reboot the printer and cancel all jobs
within the printer?s memory. In this case, you must also cancel and resend the
H. CLEANING THE CARD FEED ROLLERS
To assure consistent printer operation, all of the gray card feed rollers within the
printer should be cleaned during every ribbon change (every 250 prints) or if the
rollers are noticeably dirty. To clean these rollers, use the special adhesive-backed
Cleaning Cards from the Printer Cleaning Kit. Refer to the following steps to run a
Cleaning Card through your printer:
1. Open the Top Covers and remove all print supplies from the printer. Leave the
printer power ON and the Top Covers open throughout this procedure. The
Cleaning Roller Assembly can also remain within the printer during this
cleaning process.
2. Remove the Cleaning Card?s adhesive backing paper.
Nov 12, 2010 | Fargo Pro L ID Thermal Printer
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
My canon pixma MP610 keeps printing unasked
Jane P
hi,
try this one i think it can help your problem.
at Start menu you can see printers and faxes icon or you can also see in setting drop down menu, and click it.
if theres a list of many printers, see the one you're using, and double click it. and cancel all pending document to be print.
Tip: please don't click the printer icon several times it will only multiple the printing process.
hope this can help
God Bless.
Nov 26, 2008 | Computers & Internet
Cancel printing doesn't work
If you have tried a reboot then why don't you try a Soppler Refresh.
Click on Start> Run (and type Services.msc) Hot ok.
It should open services window up.
Then look for Print spooler> Double click on it> Under General amke sure startup type is selected as Automatic> Then down you shoul see a tab which says stop> Click Stop (Now a small windows popps up and closes) You will see Start Highlighted> Click start and stop will be higlighted> if applicable click on apply or ok and close all the windows and restart the computer.
Then go to Start> Control panel> Printers and faxes> and check to see if the icon say 0Ready> if yes right click on the icon and left lick on Properties and then in the bottom you will see a tab which says print test page> click and see if it prints a test page.
Then try printing any document.
Good Luck
Aug 20, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Laserjet 1020 reprints on logon
Turn off printer, Goto Control panel then printers and faxs, double click on your printers icon, a box opens with your pending prints, select file and cancel all documents, close all windows, restart printer
Dec 16, 2007 | HP LaserJet 1020 Printer
Last page of printing stops 3/4 through the page.
Try cleaning your heads with appropriate solution. Then, cancel all print jobs. Try again. If it does the same i would turn it off, inplug all the cables, replug all and turn on. Try again. If still no good, completely unistall printer then reinstall it. Try once more. Good luck
Jan 16, 2007 | HP PSC 2175 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
