Whirlpool GEW9200L Electric Dryer
Problem for Whirlpool GEW9200L Electric Dryer
Need new user interface
By ajdohl on Sep 02, 2009
repair guy diagnosed that we need a new user interface.
Got it online cheaper lots cheaper than he quoted.
Now how do I install it? It looks like you just plug in 2 ribbons, but I don't know how to open the panel on the dryer.
Best Solution
posted on Sep 02, 2009
Very Helpful)
jsrock516
Rank: Guru  Whirlpool Washers & Dryers  Expert
Rating: 96%, 7153 votes
If you're talking about the interface control board behind the front panel, this is a fairly simple repair. Just follow these steps:
1. Unplug the dryer.
2. Remove the top panel by locating and removing the three screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off.
3. With the top panel removed, locate the EOC board (main control board mounted on the left hand side of the drum) and remove the access cover.
4. Carefully remove the two small ribbon cables that run from the Interface Board to the EOC. NOTE: You may have to remove the EOC for better access. If you do, make sure you handle with care and don't stress the cables. Some of these connectors will have a small release tab you have to push in order to get the connector to come apart. So, if it doesn't come apart, don't force it - check for a release tab. Also, use care when handling the ribbon cables, they can be fragile.
5. With the ribbon cables disconnected from the EOC, remove the screws holding the operator console in place and lift the entire assembly straight up. This will allow you to work on the panel on a bench top or table top.
6. Lay the operator console face down and carefully remove the old Interface board and ribbon cables.
7. Install your new board being careful not to handle the board components. Some of these circuit cards are static sensitive. Try to only handle the edges of the board.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Whirlpool GEW9200L Electric
Questions and Unsolved Problems for Whirlpool GEW9200L Electric
Do you recommend Whirlpool GEW9200L Electric Dryer?
Answer
Answer
I smell a burning smell from the dryer. I was running dryer a lot today and tonight I smelt... (More)
Answer
the sensing light comes on ,you can hear a click but nothing happens. the control is not... (More)
Answer
Whirlpool Dryer M # GEW9200lwg Permaturely Stops Drying After 20 Min's of an Setting.
Answer
need to replace heating coil. need info on which wires connect to which connection on coil. Duet... (More)
Answer
does not heat on any setting. opend and pulled out tons of lint but still does not heat. how does... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
