- I will appreciate your help to solve this problem. This particular computer has been without use sice 2005 and the specifications are lost. At first could not bootup, then found the hard drive with very low capacity, When finaly loaded the (os) It was very lslow.Therefore, I need the specifications and all the help fron you. Thanks!
GQ GQ-Desktop-Series GQ 50038A SpecificationMemory Type: SDRAMMemory Speed: PC100, PC133Chipset: SiS 730SChipset : A group of chips that together make up a complete computer processing unit, usually on one circuit board (the motherboard). It may include the main central processor, graphics processors, secondary cache memory, and input-output controllers. Memory is one component controlled by the chipset.
Memory Type: Non-ECC Non-Registered, Memory Slot(s): 2Max. Memory Per System:1024MB (1GB)Max. Memory Per Slot: 512MBDual Channel Memory Support: Not SupportedDual Channel : A development in motherboard and chipset design that allows for increased bandwidth transfer when using two or more memory modules in separate transfer channels. These separate channels allow each module access to the memory controller, increasing throughput bandwidth. It is a good idea to use matched pairs of modules to ensure the best compatibility for dual channel operation.
Install Memory in Pairs: Not Required
Windows does not see the Nvidia G100 video card in the PCI-E slot. Does not even show up in device...
(More)
Windows does not see the Nvidia G100 video card in the PCI-E slot. Does not even show up in device manager. Tried to install drivers, but the driver installer says that I don't have any compatible hardware (aka, it doesn't see the card either). Everything is factory new, all drivers are p to date. Tried disabling the onboard video and setting the BIOS to default to PCI-E. No go.
My older Dell dimention 2300 created photo and audio Cd's do not play in my dell optiplex gx270 cd...
(More)
My older Dell dimention 2300 created photo and audio Cd's do not play in my dell optiplex gx270 cd rw/dvd player. Any advice?
Hi I bought a barebones U buddie 4m23/24, I took the lid off and there was a lead from the 'power...
(More)
Hi I bought a barebones U buddie 4m23/24, I took the lid off and there was a lead from the 'power on' led just hanging there - where does it fit? (and which way round) The accompying manual and quick assembly sheet do not mention it - in fact the manual is not very helpfull at all - is there a more comprehensive manual available anywhere tht I can download? thanks Barry
