Question about Sanyo VWM-900 VHS VCR
SANYO VCR VWM-900 playback is jerky
At first I thought it was the tape, but tried ti play a different tape with the same results.....
the picture seems to be ok but the audio is jerky and when you look at the picture, you can tell it is responding the same as the picture.
  • 3 more comments
  • maydole47 Dec 07, 2007
    I tried the FF/rewind trick, but it didn't help. It sounds like your analysis of the problem is accurate. I will take it to a trusted technician locally and will let you know how it works out.
    Thanks for your quick response.
  • maydole47 Dec 19, 2007
    Took it to a "trusted" tech, or so I thought. He called to say he couldn't find anything wrong, so I told him to check it when recording, not just playing.
    Didn't hear back from him for a week so I went to pick it up thinking he still found nothing wrong. He said he did notice it acting up when he recorded and tightened something up.
    I took it home to find it still was acting the same as before.
    I tried another tape that had worked in my other VCR. It appeared that the defective VCR ruined the other tape. Guess I'm out the bench fee I paid to have him look at it.
    Thanks for you advice anyway.
  • maydole47 Dec 28, 2007
    DUH! I hooked up a different VCR and had the same issue. Then I realized the problem started after I got a new TV, Sharp AQUOS. I tried playing a pre-recorded tape and had the same problem, but on a third VCR, new, on a different TV the tape played OK.
    I had trouble setting up the new VCR on the second TV until I purchased another triple video cable, so I'm thinking the real problem is in the hookup of any VCR on the new TV. I have yet to purchase new cables for the set up.
    Hope I can finally get to the correct solution soon.
  • maydole47 Dec 29, 2007
    This gets stranger and stranger.
    The cables didn't fix the problem and I tried your idea of plugging the VCR and cable box in an outlet across the room. No good.
    I have found out that it records OK by playing the recorded tape on the other VCR/TV in the other room, but when I play it back on the new TV, it skips.
    I give up. Now that I know it will record OK, I can play it back in the other room.
    Thanks for your suggestions.
    Brigadier General:
  • 6,966 Answers
Your post/description indicates that possibly the brake mechanism of the supply reel is acting up. A typical VCR has 2 reels inside that spins the tape. The left side is the supply while the right is the take up. If the brake (on the left/supply) is engaged (even partially), then the entire mechanism would have a hard time pulling the tape around the video/audio head and would partially be stretching. This would represent itself as jerky audio/video in most instances. There would possible also be a low screeching sound coming from the machine/tape. An indicator would be stretched tape - there would be uneven edges of the tape.
Since this is an electro-mechanical problem, perhaps your best course of action is to seek the services of a qualified video machine technician.
Alternately, it may be possible to loosen things up by first fast forwarding the entire tape and thereafter rewinding fully before you play it.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Posted on Dec 07, 2007
  • 1 more comment
  • Louie  Role
    Louie Role Dec 20, 2007
    Hi again,
    Sorry to hear that. Wish there was a way to further assist you but that would mean physically looking over the unit. Most cases like this, you have to consider the repair cost and the down time. Perhaps you are better off purchasing a new one. Not unless you would like to consider sending it across the globe for a look & see.
    Seasons greetings and the best of everything to you and your love ones.
  • Louie  Role
    Louie Role Dec 29, 2007
    Pls comment back soon as you have replaced the triple cable (yellow, red & white).
    Another area that you can check is the power strip or the outlet where your unit is plugged in. Verify that your unit(s) are getting enough "juice". You may also want to try plugging in your VCR to a different outlet other than the one used by the new TV. Additionally check if your VCR are rated/set as auto volts or 110 and not 220 or 240.
    Happy Holidays.
  • Louie  Role
    Can't help but scratch my head. From all indications, your new TV (Sharp AQUOS) is somehow affecting the performance of the other units specially your VCR. Other than having it look over by their service or replacement, your record there but playback in another is as good as can be at the moment.
    My compliments on determining a workable remedy.
I have a Sanyo VWM-900 VHS player. I need a belt to replace a broken one. Do you know where I can find one to buy?
electronic parts shops ( Jaycar or the like ) sell assorted belts for various makes of vcr units
try e-bay and search for vcr drive belts
Sep 30, 2016 | Sanyo VWM-900 VHS VCR
Need a owners manual for a Sanyo vcr vwm 800
Here is the manual for the next model up. It should be similar enough to fix your problem. I hope this helps.
Mar 15, 2011 | Sanyo VWM-800 VHS VCR
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
Had dish network update - can't view vcr tapes
the output of the vcr...
what is it physically wired to?
Dec 04, 2008 | Sanyo VWM-950 VHS VCR
3-4 switch
1. Set tv to channel 4
2. insert a pre-recorded tape into vcr. play once to start playback.
4. after a few seconds press play on the vcr for 3 sec you will see a playback picture.
when a picture doesn't appear on the tv screen repeat step 4.
5. press stop to stop playback.
Mar 16, 2008 | Sanyo VWM-950 VHS VCR
VHS Tape on Sanyo Doesn't play on other VCR's
the heads on the sanyo vcr may slightly be out of alignment from years of use.when playing a recorded tape from this vcr to another, the other vcr's alignment maybe right on track thus causing the poor can possibly try cleaning the heads with a head cleaner or a high grade blank tape,but i don't think this will solve the problem. but you can try.
good luck
p.s also try higher quality tapes to record on.
Feb 04, 2008 | Sanyo VWM-900 VHS VCR
Audio works but no picture
simple clean head with Q tips by hand use the head cleaner on Qtips clean good dont brack the tip on head .good luk
Dec 26, 2007 | Sanyo VWM-950 VHS VCR
Vcr spanish language
You may have your SAP settings turned on in your VCR. Check your setup menu and turn SAP off SAP stands for Secondary Audio Program, it allows for bilingual sound if the station is transmitting a SAP signal. Thank you,
Aug 27, 2007 | Sanyo VWM-900 VHS VCR
I suggest you get the Tape path cleaned up. Could be dirty video heads or a dirty Control Head. Use a good 'wet' type cleaning cassette.
Jul 03, 2007 | Sanyo VWM-950 VHS VCR
Sanyo VWM-900 VHS VCR Logo
128 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
