See if removing the disk produces a response: "No disk or non-system disk, replace and press any key" or something of this sort. That will rule out the hdd failure, alternatively you can try the hdd in an external USB casing to see if it works. Computers with broken/malfunctioning hdds very often hang, bit will come back to life if hdd is disconnected. If the hdd is fine, you most likely will have a memory or a motherboard problem. Removing/replacing or changing position of the memory may help, sometimes they have loose connectors (mind static, earth yourself before touching any of the components of your laptop).
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area...
(More)
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area but
Have tried to change the background but have had no sucess. The screen saver is easy to change as I...
(More)
Have tried to change the background but have had no sucess. The screen saver is easy to change as I thought the background would be but can not seem to figure it out. Would love to npo because I feel that the fun of having your own computer and espically one that is this cute is to be able to customize it with personal pictures! Any help on this matter would be greatly appreciated! Tahnk you for your time.
HI I have an Enpower laptop wih the model # AN5 and has windows xp. i was hoping you could tell me...
(More)
HI I have an Enpower laptop wih the model # AN5 and has windows xp. i was hoping you could tell me how to reset it back to factory settings, and wipe it out
L35-S2171, Monitor screen will not light up. Screen is new, inverter is new. I can see images when I...
(More)
L35-S2171, Monitor screen will not light up. Screen is new, inverter is new. I can see images when I shine a flashlight on the screen. The rest of the computer works just fine. What is the fix for this problem?
