Question about GE Energy Star WCVH6260F Front Load Washer
Smelly washer The washer has a powerful mildew smell that is geting worse
I found out the hard way. The GE WCVH6260 fron loading washing machine has a terrible design flaw. There is a 'filter' that sits right in front of the discharge pump. This filter clogs with lint, coins, hair, dollar bills ... etc about every 3-4 months. When it 'clogs', the pump cannot '****' the dirty water through the gunk. As a result, you have nasty, stale water (forever) preventing dirty water from being flushed. What's worse is that since the dirty water cannot leave, you wind up washing/rinsing your 'clean' clothes with dirty water. It is easy to fix.
When looking at the front of your washing machine, there is a rectangular panel at the bottom. Remove the 3 screws (left, right and center) and pull down on the panel. It slides off easy. Right in front of you is a 3" cap. MAKE SURE TO HAVE A LARGE POT TO CATCH THE SLOP BEFORE YOU LOOSEN THE CAP. Remove the cap and pull out. (I took out 'gunk' the size of a tube of racket balls (coins, hair, dollar bills .. etc). You will also see/smell what I mean by 'dirty water'
GE is a bunch of idiots. We have only had our machine 12 months. This is obviously 'regular maintenance' kind of stuff (kind of like periodically cleaning the lint filter on the washing machine) and GE doesn't even make the 3" cap accessible from the outside. I checked the manual and these problems are not even FAQ's in the manual:
* machine 'pauses' between every cycle (push start to continue)
* clothes smell musty
* water doesn't drain
* cycles (consistently) take longer than timer says
* clothes still soaking wet even after spin cycle ... etc)
Posted on Jul 05, 2008
  • nlplgreen Nov 08, 2010
    I have the same problem only Now I have a mold issue. Not sure what to do with this one. But yes the cycles are long and I have to hit the drain and spin button several times to spin out the clothes well especially anything heavy like towels and blankets.
  • 3 Answers
This is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
Posted on Oct 01, 2008
You can also try a product called Smelly Washer that was designed specifically for this problem. Go to www.smellywasher.com or ask your local hardware store.
Posted on Mar 30, 2009
  • shloime Oct 17, 2011
    IF the problem is mildew buildup from not drying and airing out the machine, then yes, running a chemical cleaner through will help. but just leaving the door open between loads, dumping out the detergent dispenser and wiping the gasket dry should have already taken care of that.
    the pump filter problem is different - there is actually a clump of "stuff" stuck down there that is growing mold. if you don't remove it by cleaning the pump filter, you might as well run the cleaner through every day or two, because mold spores are airborne, and it won't take more than a day for the mold to get re-established in a warm, moist environment like that.
    cleaning the filter is actually faster, believe it or not.
JohnfromIowa was dead on. THIS IS THE FIX, PERIOD. Read his instructions and make sure you clean the pump "tube" with a spray bleach solution ( like 10%- 1 part bleach to 10 parts water) THOROUGHLY. When you're done, run a speed wash cycle with a cup of bleach to kill any remaining mold spores. That will fix it for sure.
Posted on May 12, 2009
I just tried the solution proposed by JohnfromIowa and he is ABSOLUTELY RIGHT! I cannot believe that GE does not include this easy solution in their manual. GE chose looks over functionality as it would've made sense to include access to this filter without having to use a screwdriver. I cannot imagine how many people have paid hundreds of dollars to have their machine service by unscrupulous service techs. This is the last GE product I buy. All the other GE products that I bought for my house (dishwasher, dryer, microwave and range) two years ago are falling appart in one way or another.
No wonder why my clothes smelled musky and there was sometimes water under the washer. We've had our washer for only 2 years. After having unclogged the filter, it was amazing to see the kind of **** that came out of the drain hoses...YUCK!!
Posted on Nov 17, 2008
    Gotta go check mine....can't imagine the build up after 2 years. No wonder it smells so bad!
Run a load with a cup or two of white vinegar....works on clothes odors and washer odors. Also...vinegar is a wonderful, natural fabric softener! And no, your clothes do not come out smelling like vinegar. They just smell clean.
Posted on Jul 04, 2008
    Problem Solver:
  • 8 Answers
Complain, complain, complain........ you purchased an American made product...... like American made cars they are junk.
Posted on Aug 20, 2008
  • sammy Jan 04, 2012
    The GE Washer is MADE IN CHINA - - - - Look at the label on the side
    Champion:
  • 249 Answers
Do 95' wash with calgon or washing soda it should sort it out, let door open when it finishish milddew can build up with door closed
Posted on Dec 07, 2007
    Made in CHINA - - - Look at the label . . . .
    The GE Washer is MADE IN CHINA - - - - Look at the label on the side . . . .
Clothes smell after washing cycle
Nice, or not nice?
To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
How to Get Rid of Mold Smell in Front Loader Washing ...
www.wikihow.com > ... > Housekeeping > Cleaning > Laundry Jump to Preventing Smells in Your Front Loading Washing Machine - Part 2 of 2: Preventing Smells in Your Front Loading Washing Machine.
how to get rid of a bad smelling high efficiency washer ...
wholelifestylenutrition.com/.../learn-this-tip-say-goodbye-to-bad-smellin... Learn this tip and say goodbye to bad smelling HE washer machines forever! ... Not only did it smell moldy and musty but my clothes were starting to smell this ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Your Washing Machine Smells, and How to Clean It
laundry.reviewed.com/.../why-your-washing-machine-smells-and-how-t... Add this solution to your machine's detergent container, pour two cups of white vinegar into the drum, and run a normal load at high heat. The baking soda and vinegar should break up any residue stuck to your drum and kill any mold that might be present.
Washing Machine Smell on Pinterest ' Smelly Washing ...
https://www.pinterest.com/explore/washing-machine-smell/ Great tutorial on how to clean your front load washing machine, get rid of mold and mildew and prevent it from returning. I clean mine after every wash (a little ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Does My Washing Machine Smell Like Mildew? - Real ...
www.realsimple.com/home.../cleaning/.../mildew-smell-washing-machine To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
Jan 09, 2016 | Washing Machines
I have a Maytag Neptune model # MAH5500BWW. It appears that there is still water inside the tub after completing a wash cycle. I only noticed it as I tried to get a stuck sock from the top of the tub and...
the noise you're describing is normal - there is water in a sealed balance ring on the inner tub. To get rid of the mildew and smell, leave door open after cycle and use something like Affresh or "Smelly washer" stuff monthly or more often.
Vlad,
First Choice Appliance
Aug 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Fowl Smell
If the smell is a mildew type odor this is common with the newer energy efficient machines. To remove the odor I would suggest using a product called Affresh or Smelly washer. These used on a monthly basis will help eliminate and keep it from coming back. If it is practical to leave the lid open when not in use that will also help. The products I talked about are available at Target, Lowes and grocery stores near the laundry detergent.
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
MY newerfront load lg machine smells like mildew leaving clothes
Front load washers are very efficient but can create odors not common in top load machines. I would suggest running a cleaner such as Affresh or Smelly washer through the machine, there are instructions on the containers but basically you run a load without clothes on the hottest settings. This will help eliminate the mildew that gets caught between the tub and basket. A treatment once a month will do wonders!
You can purchase these at Target, Lowes or grocery stores near the laundry soaps.
Apr 19, 2010 | LG WM2487H Front Load Washer
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Washer will not drain completely
Some machines don`t drain all the water out.
Is it your pipe which goes from the washer to the drain.
These pipes can get very smelly.
I suggest that you just run some soda crystals through the machine on a hot wash cycle.
please try this and let me know what happens
best of luck
Jan 25, 2009 | GE WBSR3140DW Top Load Washer
Kenmore front load HE washer odor
How old is your machine? Mine is 5 years old, and I just started to get a "sewage" smell in my laundry room this weekend. I disconnected the water return to the sewer line and discovered lots of gunk in the hose, and the connector to the machine was completely dark green. I'm going to replace the hose, and trying to figure out if there is some sort of filter.
We only use He detergents too, so I guess this is something that just happens over time.
Oct 09, 2008 | Kenmore Elite 45986 Front Load Washer
Stinky towels
Mildew odor in towels in almost invariably being transferred from the washing machine. The clothes washer must be cleaned first then clean the smelly towels and laundry. To compare washer cleaners watch this video of Affresh and Smelly Washer...
http://www.youtube.com/watch?v=Ua6OJPn0-fU
Apr 19, 2008 | Washing Machines
Mildew Smell
Let me add...I was having a problem with the washer draining. I followed these instructions http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet from this website. I found two socks and they were extremely mildewed and the junk that came out smelled. It may be worth it to check and see if there is something in the pump. It wasn't very hard to do. Let me reiterate something that was mentioned...if your washer is not in a garage or somewhere you don't mind a good bit of smelly water leaking out...definitely use a shop vac first.
Feb 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
873 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
