Problem with Navman iCN 520 GPS Receiver
How to update my navman icn 520
1 Solution
  • avatar
    iblisr34 Im in Adelaide Australia do you know where to go and how much it would cost?
    Sep 02, 2009
Navman iCN 520 GPS Receiver Logo
1,103 people viewed this problem
  • 1 person found this problem to be helpful.
  • 0 people are following this problem. Be the first!
More Insights on Fixboard
1 Solution
Take it to service center and they will update it
  • avatar
    Rijul Pujari For all in warranty repairs for Navman please contact Navman Customer Service on 1300 628 626
    Sep 02, 2009
5 Suggested Solutions Relevant solutions from other related problems that we feel might be a fix.
Author image
You can unlock the iCN520 and install other GPS software on it. The iCN520 can run virtually all the major GPS software available today; from Tomtom to Miomap and beyond.
Instructions on how to unlock the iCN520 can be found at:
Source: Navman icn 520 with smartST 2005
  • Was this solution helpful? Yes No
Author image
  • Elite5
  • 4 Solutions
  • July 16, 2008
carefully pull off front grey cover with your thumb, next to card socket, underneath are 4 security screws you need a small torque head screwdriver, take off cover losen security screws inside around battery, unplug and remove battery, replace in reverse.
Source: navman icn 320
Author image
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
Source: Navman icn 520 stuck on USB screen
Author image
  • Guest
  • February 26, 2008
The CD is not available for download from Navman it seems, but you can get it at thepiratebay.com. Just search for 'navman icn' and you'll find what you need, I just did. Better learn how to download torrents though! :)
Source: Navman iCN 520
Author image
  • ginko
  • 19389 Solutions
  • March 29, 2008
There are two possibilities:
1) it is a software problem, in this case you can solve it downloading and installing a firmware update. You can download latest software from here.
This is most likely situation.
2) If the above did not work it means that you have an hardware problem, probably the touchscreen is slightly faulty, or the lcd ribbon cable is not well connected. In this case I suggest to take the navman to service.
Regards
Source: navman icn 520
Add your solution
Full Name
Top Navman GPS Devices Experts
Laurent M
  • Solutions: 57
  • Level: 1
  • Achievements: 1
dennis bullard
  • Solutions: 4090
  • Level: 3
  • Achievements: 1
Ekse
  • Solutions: 13404
  • Level: 3
  • Achievements: 3
Expert Badge
Are you a Navman GPS Device Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More iCN 520 GPS Receiver Related Problems
Unsolved Problems:
See all Navman iCN 520 GPS Receiver Problems
Loading... Loading...
