Question about Lands Phones
New Philips voip8411b phone
Using philips directions I tried to reset the default settings but not the network settings. Everything appeared as the instructions said until I to confirm then it played a little and turned off all power as the instructions said it would.But they said that the power would come back on after a few seconds. That was yesterday. I have tried every key but not a flicker of power. I emailed Philips but they said I would have to send it to them.
Can you tell me how to get this thing turned on ?
Thank You;
RL
  • Jeidbo Dec 11, 2007
    Same problem here, - any fixes yet?
  • rleloise Dec 14, 2007
    Jeido;
    I tried their phone # 1 800 233 8413 but gave up waiting for help.
    Then I went online to philips.com then to customer service, then entered voip841, then changed the top drop downs to English,
    U S and read all of the FAQ's to no avail. In that area there is a "contact us" followed by the option to email. I sent an email telling them my troubles.
    Philips sent a return email authorizing me to return the unit. I sent it in about 5 days ago and that is where it stands now.
    Good luck.
    RL
I have the same problem and could not find a contact phone or e-mail. Can you tell me the e-mail you used. Thanks.
Posted on Dec 11, 2007
    All right, here is my solution. After about an hour or so with the phone in the charger stand it just started to work. I noticed it had turned on by itself. It is working fine. So instead of a couple of seconds, the manual should say put in charger stand and wait a couple hours.
Phillips voip 841 mac driver
i use this phone via a mac. i don't recall any driver being necessary. but check philips website. type 841 into search box and then click software and drivers. link below.
good luck
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=CA&slg=ENG&cat=INTERNET_TELEPHONY_DEVICES_CA&sct=DUAL_PHONES_SU&session=20090612180105_70.79.183.10&grp=PHONES_GR&ctn=VOIP8411B/37&mid=Link_Software&hlt=Link_Software
Mar 24, 2009 | Philips VOIP8411B/37 IP Phone
Philips voip 841: no sound on skype calls, but fixed line works f
We have had this issue recently as well with both our parents and now our own.phone.
Simple solve I found here:
1. Remove batterys
2. unplug base
3. replug in base
4. Put batteries back in
Worked for us - must be a virus or something
Feb 16, 2009 | Philips VOIP8411B/37 IP Phone
Problem with philips voip841
Try retrieve the IP address of your VOIP841, on the handset press the “Menu” button, navigate to the “Settings” menu and choose the option “Network”, then "DHCP", it should give you an IP address, make a note of this. Open your Internet browser and type in the IP Address of the VOIP841 into the address bar. The Internet browser will show the internal Internet page of your device. Login with the following username and password:
Username: philips
Password: voip841
After logging in please navigate to the “Skype” menu option in the left side menu. On this page y ou can type your Skype username and password. Once they are filled in save your settings and test on the handset if everything is working.
Sep 25, 2008 | Philips VOIP8411B/37 IP Phone
Call transfer problem between Philips VOIP8411B and Plantronics C65 headset
sounds simple in the manufacture hand book that came with head set
states on some models they have this particular compatible mode built in
depending on specs of phone and headset gotta make sure that they were built with these built in specs and not all dect/gap work with other sets
Jun 02, 2008 | Philips VOIP8411B/37 IP Phone
Http server password for VOIP841?
try this...
User:philips
pw:voip841.
Jan 09, 2008 | Philips VOIP8411B/37 IP Phone
Incorrect password every time I try to login
Passwords are case-sensitive, and I found while typing in my password to the Philips VOIP8411B yesterday that the caps key was a little tricky... But once I got that down it worked...
Jan 04, 2008 | Philips VOIP8411B/37 IP Phone
Help
Sounds like you simply have to sign out from skype from the phone, change your auto-login password to the new one, then try logging back in again.
Oct 31, 2007 | Philips VOIP8411B/37 IP Phone
Philips VOIP841 Cannot connect to Skype - Adsl problem?
Right. I've fixed it!
Here's what I did.
- You need to upgrade to the latest firmware. This is available from the Philips website. Make sure you select exactly the model of your phone. There are some instructions about how to upgrade the firmware in the manual
- Then you need to perform a reset of the system. ie: get a sharp tool and ram it into the tiny little hole on the black box which comes with the phone. If you don't do this after upgrading, it doesn' t work.
- One other tip is to check the firewall settings on your router allow the traffic in/out as well.
I called the Philips service center, and they were a bit useless, but they said if it doesn't work you could try taking the batteries out of the phone for 4 hours. Hmmmm... only try this if the above doesn't work!
Good luck.
Oct 27, 2007 | Philips VOIP8411B/37 IP Phone
Phone does not work for teleconference services that require a pin number
I've found dialing numbers to navigate automated answering systems through Skype to be unreliable in general. Sometimes it works, sometimes it doesn't. This holds true for using the numpad on the keyboard, my free-1 usb skype phone, AND now the new Philips VOIP8411B I got in the mail yesterday. I'm not surprised that the Philips doesn't work, since I've had the problem before, but still disappointed...
The only way I've been able to work around this problem is to make the call on the computer and dial numbers through the on-screen number pad (using my mouse) to get through automated systems that don't work with a handheld device. Yes, this defeats the puprose of buying and using all these cool gadgets like the Philips and the free-1, but only for these certain types of calls. And even when I use the on-screen number pad, it still doesn't work sometimes. That's when I start punching numbers frantically and hoping a real person will pick up the line... lol
@Pat56 - If you use teleconferencing so much, maybe it would be best just to do it through the computer with a USB headset instead of using the Philips VOIP8411B...? Just a thought.
Lands Phones Logo
52 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
