Question about Sony Playstation 3 (PS3) Console
Some kind of feedback
I just got a 40gb PS3 today. When I hook up the A/V cables to my tv, there is some kind of feedback coming through like a low hum. when the PS3 is the only thing hooked up, it's gone. the minute I hookup everything else,including the cable, it comes right back.... does anybody have any ideas or suggestions? thanks everyone
    Brigadier General:
  • 6,966 Answers
I suspect that what you are referring to as "feedback or "low hum" is actually 60cycles AC hum coming from the mains. Though this is fairly common, it is quite challenging to figure out corrective actions since you have to do trial & error to determine which of your cables/devices combination would start the hum.
In some instances, this could be corrected by inserting the AC plug of the device the other way around to the mains outlet (if the prongs would allow it). Further, a filtered powerstrip instead of the wall outlet would probably also help.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Posted on Dec 07, 2007
How to hook up a wii to a plasma tv
follow this video you cannot go wrong. Full setup instructions please leave positive feedback and ratings for your free solution today/
Jan 31, 2010 | Sony Playstation 3 (PS3) Console
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Where do you put the memory card in the knew ps3
On the side there should be a slot for the SD card what you would need to do is pick up the manual.. But there is a slot there for memory.
Thanks and please leave positive feedback for your free answer today.
Nov 10, 2009 | Sony PlayStation 3 40GB System
When i hook up the ps3 to the hd tv it just says invalid format
Hi mate ,
prior to the issue you highlight to us ,i have a link that can assist you more detail.this is the link*mQysYIj
KINDLY RATE ME MATE!!!!!!!!Good Luck mate ....Thanks.
Oct 17, 2009 | Sony PlayStation 3 40GB System
Sound but no picture
Hook up the composite cables that come with the unit. Turn the TV on to the correct input. Turn the PS3 on using the power button on the unit. When you press the button continue holding the button until you hear a second beep....about five seconds. That should set the PS3 back to the factory output. If that corrects the problem you can set the PS3 to use whichever cable you want via the XMB.
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
How to get around Feedback?
HDMI cables will fix that. the feedback is because your playing a high res video on a low res tv (im just assuming you dont have a 1080ip TV) i had the same problem for a while until i got a 1080ip. you shouldnt have to unplug the cable.
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Audio Trouble hooking PS3 up to HD
Hi there, Have you checked that the HDMI Cable is inserted into both your PS3 and HDTV correctly ? if the cable moves about in the HDMI port that causes static sometimes ! Also check that your cable isn't damaged.
If the problem persists. i would just Use your Composite (Red,Green,Blue) connection from your TV to your PS3. you said it doesnt have static problems. and Using the composite cable you can still get the Full 1080p Resolution on your TV that the PS3 can Up-Scale to!
Hope this Helps ?!
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Sony Playstation 3 (PS3) Console Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
